Question about Canon imageRUNNER C5180 Color Copier
Can I send a document to a network folder if the copier is outside our firewall (we just moved and are using a server collocation facility)? Or, can we email documents from the copier when it is outside our firewall?
  • 149 Answers
As long as your copier has rights on the network and the email servers it should work, It generally needs administrative rights to the folder. You can set exceptions for the firewall to let it through
Posted on Oct 07, 2010
Scan and Send not sending - CAnon Image runner Advance 5045 - was working 3 weeks ago - not working now
working 3 weeks ago. well, something must have changed in your network since then, check smtp server with your mail provider if it is scan to email. if it is scan to the file, check firewall, ip addresses, destination folder, login and passowrd to the destination pc.
Jul 31, 2013 | Canon imageRUNNER 5000 Copier
I can receive faxes,but cannot send on out.
CHECK THE FOLLOWING FOLDERS IN THE CONTROL PANEL:
NETWORKING AND SHARING CENTER
PROBLEMS REPORTS
SECURITY CENTERS
WINDOWS DEFENDER
WINDOWS FIREWALL
I AM GOING TO START IN THE NETWORKING AND SHARING FOLDER AND THE WINDOWS DEFENDER AND FIREWALL 1ST
ROD
Mar 13, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I have a Kyocera CS 1820 copier, scanner, fax machine and I can't figure out how to geet it to scan to pc. I have installed the drivers from the kyocera site and still no luck......
Make sure that you downloaded the correct drivers....Etc... (x64) vs (x86) also make sure you have the proper script # driver ... Etc... #5.1 vs #6. You will want to completely uninstall all the old drivers, shut down your computer --- do not just reboot, reinstall all the new drivers,and after your computer is done rebooting – shut it down and restart. Also make sure that you and the designated file set up on the computer, it needs to know where to scan the document and send it to.
Dec 23, 2008 | Kyocera Copystar CS-1820 Black and White...
VPN Access does not work
Use should add arp proxy setting as the following:
Go to Interfaces and then click on PPTP/L2TP server from the PPTP/L2TP Page go to the Add ROute Tab.
Allowed Networks should be : All Nets
under Proxy Arp you have 2 Boxes:
One is: Available and the other is Selected.
Under Available click on LAN and move it to Selected.
now save and activate and it should work.
Dec 18, 2008 | D-Link Netdefend DFL-210 (DFL210)...
Sending to a file setup
No, you can't retrieve deleted phonebooks so far as I'm aware but probably you're not referring to phonebooks because there probably is no phone. But sending to a file should be quite easy. Now, as you've posted on a Canon thread, I hope you are referring to a canon, a clc or irc. If this is the case then all you do when scanning your document is in the top right hand corner where you will, by default, see 'email' you can use the drop down menu to select 'file'. Now, you will then be able to use the down arrow keys on the main display to search your network for the relevant 'shared' folder and select it. Remember, the folder must be 'shared' for the canon to see and select it and there must be no conflicting firewalls. If passwords have been set up for network access the machine will prompt you to enter it where necessary. Once you have arrived at the3 destination folder you can scan your document to it. You can set up your address book in the same way so you don't have to go through this whole procedure everytime.
Need a Canon Copier Service Manual
Nov 24, 2008 | Canon imageRUNNER C3200 Color Printer
Sharp MX-2300N trying to send image to email address gives error
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Nov 21, 2008 | Sharp MX-2300N Color Copier
Konica Minolta Bizhub Copier/Printer How to Scan
When specifying the destination you need to complete the address to include the folder. Just like specifying a path manually, the server/folder.
You need add the folder as part of the server path.
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Canon copiers c3100, ir5000, & ir7200 scanning files issue.
Ok, so working thru the troubleshooting model you have identified the symptoms fairly well but I dont know if you have adequately identified the area affected. In order for the copiers to create a file on a network server they need user names and passwords to access a network resource and they need sufficient rights to create a file. Have you tried to log into the scan folder on the server using the copiers credentials from a workstation?
The next step, of course is to identify what has changed.If you had a problem with a domain controller is it possible the user accounts for the copiers got deleted/damaged/modified?
Log into the internal web page of the copier by plugging its ip address into the address bar of your favourite web browser and verify that its network settings (dns server, domain name, etc) are correct. I believe you can ping the server from the web page as well, if not it can be done from the tcp/ip setup screen on the copier control panel.
There is no way to manually flush the DNS cache on the copiers except for powercycling the device, just make sure you are turning it off by the main power switch near the back of the machine and not the on-off button on the control panel.
I dunno if this qualifies as a solution or a clarification request but I would start with the user accounts and access permissions.
HTH
Jun 12, 2008 | Canon ImageRunner 2220I Copier
FTP problems.
There are 2 ports used for FTP. They are 20 and 21. When you initiate a connection that occurs on port 21, but data traffic is on port 20. Your firewall sees your outside FTP server trying to 'initiate' a connection on port 20 and breaks the connection to that IP address.
What you need to do is either use 'passive' ftp or open both ports 20 and 21 for ftp traffic in the firewall.
Apr 02, 2008 | D-Link DFL-800 Firewall
Unable to send a print job to the device.
i know what your problem is phone 07764303923
Oct 06, 2007 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER C5180 Color Copier Logo
57 people viewed this question
old marine
old marine
