Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture gets bright then blinks black, adjusts and then gets bright and blinks again every 4 seconds. used to be every couple of minutes.
  • Sony Master
  • 8,457 Answers
Take the tv aparts.Caution high voltage ERA FBT.The FBT the flyback transformer.That the big block of plastic,with a red wire with a cap hook to the CRT(Tv tube).On FBT that big block of plastic there are 2 knobs one said FOCUS the other said SCREEN.Turn knob said sceen down a bit,will stop get very bright pictures and shutdown,the screen will hold high voltages.
Posted on Oct 06, 2010
  • cocodel51 Oct 07, 2010
    thank you for your response, and the info. maybe im missing somthing?
    on plastic thingy i found two phillips adjusting screws , unnamed (no focus no screen) .. adjusted as you suggested, and picture was beautiful (no blinking) for about 3 minutes. i was soo excited wanted to wake up my wife. glad i didnt cuz blinking and washed out color returned as soon as i attempted to adjust picture thru t.v. menu...
    . I did like you said, adjusting bottom screw, when turned all the way right, shut tv off. when turned a little, bright pink... when too far to the left, no picture (black screeen). in between, no change except no longer seems to get brighter and then blink, it stays bright and blinks. top screw does not seem to affect anything???
Hello, I have a Sony KDS-55A2000 and it works fine for a couple of minutes and then it switches off and the green led starts blinking for about a minute and then the picture comes back and works fine
First thought would be the lamp may be about to fail if it has not been replaced in a long time---a warning will be the picture is a bit darker than before and takes longer to get bright than it once did.
Apr 17, 2012 | Sony KDS55A2000 55" HDTV
T V blinks to black every few seconds otherwise works fine
Sony put i pic killer circut in there tvs. if the tube was not
giving the proper feed voltage on the guns in
the pic tube it blinks off ,sound good no pic.
if you turn up the brightness
on the flyback transfromer you can
get a little more life out of it ,
Jun 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 42" KV-32S66: picture blinks off briefly, getting worse
your crt is getting weak you can get around this buy adjusting the screen control ...... the screen control is on the small board on the back of the picture tube . remove back , with picture tube flashing adjust screen control a touch one way will make it worse and the other will stop the flashing . only move it as much as you need to - no more . this will work for a while and you can do it again and again when ever needed . but the picture will not be as good .... as far as the free dead sony , i would get it . changeing a picture tube from doner tv is just plug and play on a sony . so you can have a new tv for free with just a little work ..........if this answer helped please rate it 3 or 4 stars . a high rateing will help keep mein the paid answer department thanks
Apr 04, 2009 | Sony Televison & Video
No picture, black screen
Not a TV Technician, use the following information at your own risk. Two things you can do first: using the keys on the front of your set press and hold the menu button when while holding it down it goes from menu to channel listing press the adjust (<->) and channel up buttons simultaneously to get to the factory set up screen once there use the select button to scroll to next set up screens locate the contrast it should range from 1-63 find the one you like. Second: for the horizontal lines not to say that this is the solution there are two adjustment apparatuses inside the TV chassis if your familiar with taking the set apart and not getting shocked and hurt59274cc.jpg two dials on the fly back transformer ones for focus the other brightness you can try these fixes but I have to say again that you use at your own risk. I do hope though that the information is useful
Mar 18, 2009 | Zenith B25A02Z TV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Picture blinks in and out every few seconds
The lines in the picture and the blinking makes me think maybe the digital / logic board is going bad.. you will need a tech to resolve this and it will be expensive.. In time you will loss the picture altogether as the board will get worse.
Jul 06, 2008 | Vizio L32 32 in. LCD HDTV
KP-46S4U lose picture after a few second blink of brightness
does the from led blink if so how mant times pause then blink again?
Feb 12, 2008 | Sony KP-48S65 48" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
