Question about Belkin (F5D7230-4) Router (587009)
Can I change channel/frequency to get a stronger signal between the PC and the Belkin54g router? If so, how?
    Scholar:
  • 86 Answers
Hi i go your issue .......
You can change the channel and the frequency to get a better signal range ......
To promote this please follow the following steps
Step 1: Connected modem>>router>>computer
Step 2: Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3: Towards the left corner click channel and ssid under wireless
Step 4: on the left under wireless click channel and SSID
Step 5 :Change the Wireless channel to 6 and also you can change the frequency there
Step 6 : Change the SSID to a different name ( no Spaces )
Step 7 : Click apply changes
Step 8 : Now Scan and connect to this network ( Wireless )
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Thanks with regards priya
Posted on Oct 07, 2010
What can i do to stop from going back to homepage every five decounfs while im browsing the net
While clearing the cache and checking your network settings are excellent suggestions, if they DO NOT resolve the problem then it is likely you have a weak or bad connection to your Internet provider (either the cellural data link and/or the WiFi link). This can occur due to a weak or intermittent signal or due to strong signal interference. I suspect the latter because you seem to be able to connect easily (indicating at least a good initial signal), but then it abruptly drops. Interference can come from many sources (motors, microwave oven, competing radio signals, nearby electrical lines, or a neighbor's WiFi signal on the same frequency and channel, etc.) It can also be caused by other devices on your own network such as a satellite box, a printer, or a streaming device that also connects to your Internet provider's signal.
A simple way to troubleshoot WiFi interference is to look at other ambient signals. Download an app called WiFi Analyzer from the Google Playstore. Run the app and very slowly move around the areas where you access the Internet. All measurable ambient signals will be displayed, including your primary signal, with their channel and relative signal strength. If there are others that approach or surpass your primary signal on the same channel, then WiFi interference is a likely source of your problem. The fix: change your router's signal to another (unused) channel. This is done by entering the router's setup routine and modifying that setting (usually at an internal URL address at or similar to http://192.168.1.1 - the exact URL and directions are on the documentation that came with your router or on the manufacturer's website).
The WiFi Analyzer may well identify the problem. But it will not identify other local sources of interference nor a weak primary signal, such as mentioned above. But changing the router channel may still help.
Or, you may eventually need to invest in a better router (N or AC protocol, and dual frequency) and/or switch to another service provider with a stronger signal in your area.
Jun 06, 2015 | HTC Desire Cell Phone
Tip
Wireless Tip: Does you wireless router keep disconnecting / dropping the...
Home wireless networks that are based on the 802.11b or 802.11g/n standards transmit their signal in a narrow radio frequency range of 2.4 GHz. Various other electronic devices in a home, such as cordless phones, garage door openers, baby monitors, and microwave ovens, may use this same frequency range. Any such device can interfere with a Wi-FI home network, slowing down its performance and potentially breaking network connections.
The 2.4 GHz Wi-Fi signal range is divided into a number of smaller bands or "channels," similar to television channels. Many wireless products ship with a default Wi-Fi channel of 6. If encountering interference from other devices within the home, consider changing the channel up or down to avoid it. Some Wi-Fi channel numbers overlap with each other. Channel 1 uses the lowest frequency band and each subsequent channel increases the frequency slightly. Therefore, the further apart two channel numbers are, the less the degree of overlap and likelihood of interference.
If this won't work, try to update or upgrade your wireless network device driver software. Visit your PC/Wireless device manufacturer's website and look for the appropriate updated driver. If the problem continues after doing all these, then consider buying a new wireless router as your current is deemed broken.
on Mar 27, 2011 | Computers & Internet
How do i change channels on my router
You change the channel in the router's wireless setting.
This does not give you a stronger signal BUT you can select a different channel so you do not get interference with other wireless routers in your area that are broadcasting on the same channel.
Oct 15, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Losing signal 20 metrers away
FIrst check for any type of RF( radio Frequency) intererence in your area. Next, log into the router using the default gateway ip address and change the signal channel. The signal channel is locate under channel and ssid into the Belkin's router control panel
Jun 06, 2011 | Belkin (F6D42304) Wireless Router
Only get 1 bar on my i phone 4 cloe to the router
What you can do here to correct this problem is to access the router setup page and play around with its wireless settings that will provide a stronger signal for your wireless network , the most possible settings that you can change to improve the signal from the wireless router is to change the wireless channel of the router and see which channel works fine with your wireless network and with your IPHONE.
Mar 04, 2011 | Linksys WRT300N Wireless Router
How do I change the frequency of my router
Here are the steps to change frequency:
1. Open a web browser and type the IP address of the router into the navigation bar. For most routers, the IP address is 192.168.1.1.
2. Enter your username and password into the prompt. This is the administration password to access the router's console.
3. Click the "Wireless" tab. Select "Basic Wireless Settings." This opens a window with a "Channel" section. This section is where frequency settings are changed.
4. Select channel 1, 6 or 11. These channels provide the clearest signal since they do not overlap other channels. Click the "Save" button and close the browser window.
5. Reboot the wireless computers. A change in frequency drops wireless devices from the network. The computers need to be rebooted to find new network settings.
Nov 08, 2010 | Computers & Internet
Hi! Bernie here, I have an Linksys E1000 wireless-n router. How could I adjust the interference on my phone (Vtech 2.4ghz) is there an adjustment to make on the router itself or do I have to buy another...
E1000 router is not a dual band router.
It works only on 2.4 GHZ wireless signal.
You can try changine the wireless channel on the router.
If you have installed the Cisco conect software on your computer, then open the Cisco connect software. Go to router settings. Click on advanced settings. It will open the setup page of the router. Go to wireless tab.
Set the configuration view to Manual.
change the channel to 11. See if that works.
If not then change the channel to 1 and check it.
Click Here for more information about the routers and network
Oct 15, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Stopped broadcasting signal to the rest of the apartment. only works in the small office
You can first access the router setup page and change the wireless channel to the highest value to broadcast stronger signal but if that doesn't correct the problem do a firmware upgrade on your router............
Oct 25, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Very short range
No this is not typical if the Network card and router are just one room away. However electrical interference and walls do impede the signal.
Try moving the Router around to see if the signal improves.
You can also adjust the antenna and pointing it in the direction of the Router.
1. Position your wireless router (or wireless access point) in a central location.
2. Move the router off the floor and away from walls and metal objects. (Such as Metal file cabinets)
3. Replace your router's antenna.
Antennas supplied with your router are designed to be omni-directional, meaning they broadcast in all directions around the router. Upgrade to a hi-gain antenna that focuses the wireless signals only one direction. You can aim the signal in the direction you need most.
4. You can add wireless repeaters. (just the room next door this would be a last resort if all else fails)
5. Change your wireless channel. You may find one that will transmit a stronger signal.
6. Reduce wireless interference
If you have cordless phones or other wireless electronics in your home, your computer might not be able to "hear" your router over the noise from the other devices.. To quite the noise, avoid wireless electronics that use the 2.4 GHz frequency. Instead, look for cordless phones that use the 5.8 Ghz or 900 MHz frequencies.
7. Update your firmware or your network adapter driver
Source:
http://www.microsoft.com/athome/setup/wirelesstips.aspx
Nice diagrams on this web page too.
(Couple items left off as these did not seem to fit your current situation)
Oct 06, 2009 | Belkin Dual-Band Wireless A+G Desktop...
Stronger wireless card
There are no stronger or weaker cards (if your's is a 802.11g, which it most probably is unless its VERY old) ...you can try changing the channel on your wireless router...
Feb 17, 2009 | IBM ThinkPad X30 2672 Notebook
Belkin (F5D7230-4) Router (587009) Logo
136 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
