Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Clutch smokes while sawing. is it too tight or lose? is there a setting?
  • 394 Answers
No setting on clutch. engages with centrifugal force.There should be a ring you can remove from the shaft to remove the clutch cover and inspect the clutch fibers. Possibly worn. The clutch assembly can be replaced.
Good Luck,
Wayne
Posted on Oct 06, 2010
Smoke coming out the top exhaust and engine is useing oil
Make sure oil cap is on tight. Take it off and put it on correctly. You are losing oil and engine power. Also make sure your oil is up to the full mark on the oil stick. Don't overfill.
Dec 15, 2017 | Cars & Trucks
The saw runs but chain doesn't turn and it starts t smoke, is the clutch bad ?
Sounds like you haven't read the manual.! Is the chain brake still on.?? The chainsaw has a centrifugal clutch, the more the saw revs, the harder the clutch grips. Sounds like you have the chain brake applied and the clutch is trying to turn the drum which is being held by the brake band
Mar 08, 2015 | Stihl Garden
New Rancher 455. Ran for a few minutes then tried to tighten chain but adjuster was maxed out (completely tight clockwise). Removed cover, now can't get tension adjusting pin in hole in bar....pin sits...
Ok.. with the cover off the clutch you notice the screw and the pin that is suppose to go into the hole.. with the chain on the bar back the screw until the pin sits in the hole of the bar.. The chain should be lose you will see the chain dangle at the bottom of the bar.. put the cover back on with it lose.. hand tighten the two nuts that hold the cover on. with the bar in hand and you pulling the bar up make sure the two nuts are on tight enough so the bar does not move but dont over tighten it. tighten the screw you will notice the chain starting to move, and start to tighten up.. once the chain is in the grove of the bar grab the chain and move the chain with your hand to make sure you have not over tighten it. if the chain moves freely and is not lose ( you can also double check how tight it is by grabbing the chain below the bar and letting it go if it snaps back into the bar and doesnt hang there you are where you need to be.) tighten the two nuts up on the cover and start up the saw. Run the saw to make sure everything is all set and nothing is lose before cutting.. If the chain never get to tighten up you need a new chain. buy a new chain and follow the steps again. let me know if you have any questions
Jun 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I am using a borrowed Husqvarna model 51 chainsaw (aprrox 18") and having a problem with the chain seizing up. It worked fine for 30 minutes or more, and then the chain suddenly had much more...
Sounds like the bar is to tight.There should be a cover and 2 studs,loosen the nuts and then look for an adjusting screw at the back of the bar and back it off.The chain should have about 1/8 slack when pulled from the bottom of the bar.A tight chain will heat the bar and turn it blue close to the chain guide.A new bar will be required. Thank you for using FixYa .
May 11, 2011 | Husqvarna Chain Saw Models 51, 55
The engine starts but the chain does not move even when the throttle is applied and then it starts to smoke the whine does not sound like it has full power either
Can you move the chain by hand? If not, the chain brake may be set or damaged so that the chain cannot move. Is the chain adjusted extremely tight? Is bar oil getting to the chain? The smoke is probably coming from the clutch which is trying to drive the chain. The chain should be adjusted so that the chain just comes up to the lower bar edge, but allows free turning of the chain by hand. Get back to us if you need further help.
Nov 03, 2010 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
Starts but chain wont turn. and white smoke comes out the side where chain is. is it the clutch thats burn out?
Grasp the forward most upper handle (hand guard), move it forward, did it click? If no the brake is released. Pull it aft until the brake latches open (clicks), may require some grunt at rear extreme.
Remove the clutch cover, bar and chain. Start the saw, does it still smoke? Yes post back below, no reassemble your saw, ensure the brake is open. Start teh saw. Smoke? If yes post back below.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Garden
Engine smoke when chain brake on
It sounds like the band is too tight and the smoke is coming from a burning clutch. You need to get your owners manual and loosen the band before you burn the parts up.
Feb 23, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Husqvarna 345 chainsaw chain doesn't move freely and heats up
has the chain ever came off the saw?and i'm going to assume that it is the correct chain for the saw...reason i ask about the chain comming off the saw is that when it does the driver have a tendency to become nicked and will heat up the clutch because the saw is trying to drive the chain links through the chain slot.also you need to look at the drive sprocket to see if there is any wear on the teeth....also over tighting the chain will cause the clutch to heat up.
Feb 22, 2009 | Husqvarna Garden
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
160 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
