Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Sour milk odor in top mount freezer, model 970-608921
A pop bottle froze,burst ,glass splinters pierced bag of milk.some milk seeping into vent area at front of freezer bottom next to door.
on to sme kind of foam barrier insde vent
What can I do to remove milk and sour odor?
  • deoyamba May 28, 2008
    what should Ido?
  • ponza Jun 27, 2008
    I have a kenmore refrigerator with freezer on top. I shut the frig off the other day and I forgot I had a turkey in the freezer. It defrosted and what a smell. Blood all at bottom of freezer and maybe went into front vent of freezer. I tried bleaching and cleaning it out. I put the frig back on thinking that maybe if it froze it would not smell so bad. I wanted to spray the bleach into the vent, but I'm afraid to damage it. What should I do.
  • 290 Answers
SOURCE: Foul rotting vegetable type odor in top of Kenmore refrigerator
If the icemaker motor or heater short out it will cause a foul odor. I have never heard it described as cooked broccoli, but it can be pretty bad. Remove the icemaker and inspect the bottom of it where the heater element is and remove the white cover of the motor and look in there. You can take the three screws out of the motor module and see if anything is burned on it.
If you can rule out the icemaker, the next things to check would be the evaporator fan motor and defrost heater. Generally, if a fan motor starts causing an odor it will stop running completely and if a defrost heater goes out it will quit defrosting. It is possible, but unlikely, that something has gotten into the evaporator area and is sitting on the defrost heater so that it is "cooking" during the defrost cycle.
Check the icemaker first, it is the most likely cause of the odor. Post back with complete model number if you need further assistance and we will go through checking everything else.
Posted on Oct 24, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore Frig-bottom freezer/freezer door pops open
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Posted on Feb 06, 2009
  • 163 Answers
SOURCE: Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Posted on Mar 09, 2009
  • 10 Answers
SOURCE: smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Posted on Mar 12, 2009
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
My eggs froze. Just bought 2 doz eggs and put them in fridge on the shelf above the crisper,went to use them and they have frozen
thats the coldest spot in fridge also might want to raise the temp in fridge a few degrees
Oct 29, 2016 | Refrigerators
Milk leaked out into the back seat our truck I didn't know it until it started to smell. Iv'e sprayed nearly a whole bottle of febreze for fabric on it. while it is wet with the spray you can't smell the...
Try baking soda.
Take a box or two of it and sprinkle it all over the area where the milk was.
Leave it for up to week, and be careful to keep it dry.
Later on, you can vacuum up the "dust".
God bless your efforts.
Dec 11, 2017 | Ovens
Icecream not staying froze meat stays frozen though
Meat is always more dense than frozen dairy product. This soft ice cream issue usually occurs when the circulating fan becomes blocked due to overloading.
Unlike a chest type freezer, top mounted freezers use a fan to circulate to the refrigerator. If the return vents to the freezer become blocked by too many small items, or loose plastic bags the compressor may run too long in an attempt to lower the refrigerator temp,
This may cause the compressor to heat up and kick in the overload safety, further dropping the total temperature.
Mar 05, 2010 | General Electric GTR16BBSR Top Freezer...
Sour Vinager odor in vents when using AC in a 2003 325i???
milk may have been split in the vents
it goes very sour & vandals sometimes do it on the street!
Jul 20, 2009 | 2003 BMW 325
Terrible odor from bottom front of fridge
The milk probably is gone, but there may be something in your coils. Inspect from front at the bottom, behind toe kick trim or from the back by removeing the access panel on the lower back of the frig. Coil cleaning should be done with the frig unplugged, vacuum out the dust and with a small brush resembling a bottle brush but smaller. clean between the coils. Don't force the brush. Twisting with light pressure will work just fine.
Jul 09, 2009 | Refrigerators
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Fridge has hot spot
Hit it with a big stick!
Mar 24, 2008 | Refrigerators
well it didnt get into the compressor area, but it definalty spilled in to evaporatr area, and landed on defrost heater. so yea your smelling boiled spoiled milk!!!mmmmm!!!! you would have to rermove back panel of freezer compartment to fully see the extent of spillage, as far aswhat got under refirig into drain pan, you can problably pull unit forward and remove back panel look into pan for spillage.
compressor would'nt be affected
Mar 05, 2008 | GE PDS20MBS Bottom Freezer Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
100 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
