Question about Brother HL-2040 Laser Printer
Drum light flashes - Brother HL-2040 Laser Printer
  • Brother Master
  • 5,096 Answers
This means that you will need to replace the drum soon. Order a new drum and when the light becomes steady or the print quality becomes poor, replace the drum. The drum should last ~12,000 pages. The part number is DR350. You may be able to order this from your Office Supply store; otherwise try the Brother Mall site: http://www.brothermall.com/Accessories/AccessoryDetail.aspx?AccessID=DR350&AspxAutoDetectCookieSupport=1 .
The procedure is similar to replacing the toner but instead of putting a new thing of toner inside the drum, you remove the toner and put it in the new drum. Open the front cover and pull out the drum and toner assembly. Place on newspaper or other disposable material (toner may spill). Push down the blue lever to unlock the toner cartridge. Remove the cartridge from the drum. Unpack the new drum (keep it out of the light until ready to replace the drum). Push the toner cartridge into the new drum until it locks into place; the blue lever should lift automatically. Put the assembly back in the printer. Clean the printer as recommended in the manual while it is open; this includes cleaning the corona wire before replacing the drum assembly.
After replacing the drum, reset the drum counter: with the printer on and the drum light blinking, open the front cover and press and hold the GO button until all of the LEDs light up (about 4 seconds). Then release the GO button and close the cover. Check that the drum light is off. (The manual says you should do the reset first but I tend to avoid this in case of distractions.)
I hope this helps.
Posted on Oct 06, 2010
The replace drum light was flashing. I replaced the drum and the light is still flashing.
open front door and hold in cancel button until all lights flash up and down like crazy close front cover and u reset ur drum
Nov 21, 2011 | Dell 1720dn Laser Printer
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Jun 23, 2010 | Dell 1720dn Laser Printer
Brother HL5250DN PRINTER THE DRUM LIGHT KEEPS ON
it has a drum sensor ,it was disable to work but it look like new please change ot replace drum unite not only drum total unite then solve your problem
thanks Tareq
Nov 11, 2009 | Brother HL 5250DN Laser Printer
Brother HL 2040 drum light flashing after drum replacement
The drum light is triggered by a page counter. To reset it, hold the GO button with the drum door opened until the light goes out (10 seconds). Close the door and it should be reset.
Aug 07, 2009 | Brother HL-2040 Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Drum Light flashing
You can continue to use the printer, but when print quality deteriorates, replace drum. Light will continue to flash until you do so.
Please rate me :)
Apr 04, 2009 | Brother HL-2040 Laser Printer
Drum replaced light keeps flashing
When the print quality deteriorates and the drum light is flashing you can replace teh drum but the light will continue to flash until you reset it. Do this by opening the front of the printer and holding down the Go button for about 4 seconds until all four lights on the display are illuminated. It should be fine after that.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Drum Light is flashing yellow
Drum light flashing yellow means the drum is near it's end-of-life. There is some life left in the drum at this point. Do the following to get some more mileage out of your current drum and also when you finally do replace it (this resets the drum counter):
  • Printer on and paper loaded
  • Press and hold blue button until all LEDs light up
  • Release button
Oct 28, 2008 | Brother HL 5140 Laser Printer
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
Brother HL-2040 Laser Printer Logo
402 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
