Question about GoVideo R6640 DVD Recorder
CAN'T RECORD ON DEMAND MOVIES
I HAVE CABLE TV WITH ON DEMAND I CAN'T RECORD ANY MOVIES FROM ON DEMAND BECAUSE IT DOES'NT HAVE A CHANNEL TO SET, SO I CAN'T RECORD ANY MOVIES WHAT DO I DO?
  • Anonymous Feb 28, 2009
    I can't record a movie from On Demand to my DVR. How is that accomplished?
Panasonic dvd recorder model dmr es 15 records Comcast on Demand programs. I use it. it's an older model so you probably have to get it on eBay.
Posted on May 12, 2010
Anyone know how i can record on demand movies onto a dvd recorder
Posted on Nov 24, 2008
TV says there is a "demand button" to push to see free movies on demand. Where is it?
To get free movies ON DEMAND you need either a cable/sky box or a smart TV then you can access Shaw/ Cogeco/ Time Warner/ CTV to access free movies!
Feb 15, 2015 | Televison & Video
How to set up tv to vcr
Hook cable or antenna to in on vcr, hook either with cable from out on vcr to tv. Have tv on 3 or 4---most sets have slide switch on back of vcr.
turn both on and use vcr to change channels if you want or to play or record a movie. If not using vcr turn it off and change channels in regular fashion on the tv.
Mar 18, 2012 | Philips Televison & Video
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Connecting Hitachi VCR to my Direct TV.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
Jan 28, 2009 | Hitachi VTF392A VCR
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
I cant get go video model #r6740 to be able to be connected to my cable box and still work help please
connect the yellow, white, and red cables from your cable box (output) to the (input 1) connector on the dvd recorder. Then connect the yellow, white, and red cables from your dvd recorder (output) to a (input) on your tv (make a note as to which input on the tv you use). then turn on your tv (set your tv by pressing input, line, or channel down from channel 2 until you see the input you connected your dvd recorder to). then power your dvd recorder on (you should see it on your tv screen), then change the input on your dvd recorder to input 1 (or which ever one you connected your cable box to). Then power on your cable box (now you should see your cable programming on your tv, passing through your dvd recorder). Now you should be all set to watch, and record what ever you want, (however most dvd recorders will not record copyrighted materal, their is a signal transmited ny the owner of the movie, or other content.)
May 11, 2008 | Televison & Video
Cable hookup and av hookup
Connect your TV to AV1 and you SAT/Cable Decoder to AV2.
on the video select the AV2 channel and it will record whatever is connected to AV2. The AV channel selected it is the input the one not selected is the output.
Some PPV Movie channels are copy protected with some service providers. But most channels are recordable.
The aerial lead coming in your house connects to the SAT/Cable Decoder 1st, then connect the output socket on that to the Video/DVD then the output on that to the TV. As long as the leads you use have different ends on you CANNOT plug them into the wrong socket. As the the aerial passes through each device, the device adds its own RF channel to the feed, so you should be able to tune both a SAT/Cable and a Video/DVD channel onto the TV set aside from using AV/Scart.
Dec 27, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Recording from one vhs recorder to another.
If your plan is to copy a VHS movie to a blank VHS tape, the connections would require a 3 wire RCA connector/cable. The unit where the original movie will be played will be the player. Connect the yellow video RCA cable to the VIDEO OUT, the red & white to the AUDIO L/R OUT. On the 2nd unit designated as recorder, slip in the blank VHS tape. Connect the other end of the RCA 3 wire cable to yellow VIDEO IN, the red & white to the AUDIO L/R IN. Connect the RF OUT of the 2nd unit (recorder to the ANT IN of a TV set. Set the TV to either Channel 3 or 4 as the case may be.
If the recorder has a manual selector or via remote, pls verify that it is set to Video and not tuner (or channels) input.
Press Record on the recorder (2nd unit), press play on the 1st unit (player). The TV will serve as monitor to your copying progress.
Hope that this be of some help/idea. Pls post back how things turned out or shoould you need additional information.
Nov 11, 2007 | Televison & Video
Lines across screen when using View On Demand channels
Could be a couple of things causing this.
1) Obvious, but I assume that you subscribe to these services, because otherwise it could be the encryption.
2) Make sure that you have the set-top box connected directly to the TV, and not through an external recorder (VCR, DVD etc)
This would be a problem if the services were copy protected in the same way DVDs are.
You could also check the settings on the set-topbox. Make sure the video output is set to RGB.
Aug 05, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
GoVideo R6640 DVD Recorder Logo
583 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
