Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
My microwave's turntable seems to be problematic. It is beginning to burn popcorn (every time) and does not seem to be heating very consistently. The turntable goes around but seems to stop at the quarter mark instead of turning continuously. Please advise. Thanks
    Champion:
  • 248 Answers
This model has been discontinued,replaced with model kcms1555sss,probably cant get parts if needed.sorry cant be of more help
Posted on Oct 07, 2010
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Magic Chef MCD1611W
Turntable
The turntable motor will need to be replaced, a common issue.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Unit seems to have a sensor problem: wont pop popcorn, or heat cold food but marginly heats water. During popcorn we get error message re. Sensor.
in 99 % of cases the problem is the magnatron it is a very expensive part and unless the microwave is well worth the money we normally write the units off
sorry (
but i hope this helps
best of wishes
please remember to take the time to rank this reply .
Dec 08, 2010 | GE JE1590 Convection / Microwave Oven
Burn popcorn???
I have never found a microwave oven that worked perfectly for popcorn. If you are using the "popcorn" button it can only guess at what your popcorn needs. This is my soultion at work as well as at home or a fiends place. I watch the process and listen to the pooping. When it get down to two seconds between pops I shut it off. Each type of popcorn will act differently but if you keep using it and keep using the same microwave, eventually through a process of testing you can come to a time that will work with your process. One other thing the popcorn has to be on a rotating table and has to be put in with the correct side up. You will never get it perfect but you want to cut it off before it begins to burn.
Sep 20, 2010 | LG LRM1260SW Microwave Oven
Toaster Master 1979 has less power
Because the microwave energy is beamed into the interior of the microwave and then dispersed by a metallic "stirrer," the pattern of the energy can be fairly consistent, rather than completely random. But this pattern sometimes causes certain portions of the food to overcook (creating tough spots) and others to undercook. A microwave oven with a carousel is far better at cooking the food consistently--the pattern becomes quite random while the carousel is turning.
Nov 13, 2008 | Microwave Ovens
Pan. microwave nns762bf has low/poor heat
Assuming the line voltage, turntable and stirrer are okay, low heat will be a bad magnetron.
Nov 06, 2008 | Microwave Ovens
Heat's water great , won't pop corn
It may be a food placement issue or possibly a bad humidity sensor.
I always recommend that folks put food off-center on the turntable (not in the center) to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. Microwave popcorn gets hot enough to do that.
We have the entire service manual at our site if your or a friend want to look that over: http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
If you need a new sensor, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 02, 2007 | Sharp R-820B Convection/Microwave Oven
Microwave nuked by popcorn popper, please help?
Sounds like the magnetron has failed. That gutteral sound is a classic symptom. I've described it to my customers as sounding like gurgling into a coffee cup. Dry popcorn is a very dry food, so not as much of the energy is absorbed. When that happens, more microwaves can reflect back to the magnetron and damage it. I'm surprised they don't mention that if and when you don't use butter. But if this is an older microwave, it may have been on its way out already. Not too many parts seem to be available for this Welbilt model, but your best bet if you want it repaired is to call their nuumber in your owner's manual. If it's older or a fairly simple counter-top microwave, then it would probably be more economcial to replace the oven.
Feb 20, 2007 | Welbilt MR95TW Microwave Oven
Microwave Turntable
Microwave popcorn gets VERY hot while cooking. Even though the turntable is made of temepred glass, intense heat applied in the same spot over and over can weaken the molecular structure of the glass. After so many expansions and contractions, it will crack because fatigue will cause some molecules to expand less than others, creating stress. This is yet another reason I recommend to my customers that they place the food off-center on the tray - not in the center. The oven also heats better when the food is off-center because the food is more thoroughly exposed to the microwave energy. Until you get a new tray, the photo below can help you.
Nov 15, 2006 | Jenn-Air JMV8208AAS Microwave Oven
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
128 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
