Question about GE Dryers
My GE Gas Dryer won't start. It is the DHDSR46 model, about 3 yrs old. When I turn the Start switch to the right to turn it on, it seems to go, only to stop when I release the switch.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. I believe I replied to you question few days back however If the vent is clean then it seems to be the issue with the Thermal Fuse/Thermostat going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. You can check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 10, 2010
Ge dryer model dhdsr46
There should be two tabs on the back wall that look like metal strips. Those are the sensors and they rely on the clothes to touch them every so often to get and idea how moist they are. The sensor is most likely not the case. You should check the wires to it but it is probably the control board
Jun 17, 2013 | Dryers
Have a GE Dryer model DCL333EAOWW that will not turn on. Circuit breaker to wall outlet fine. Thought it might be switch behind 1/4 turn knob you use to turn it on. Replaced switch. Still won't start....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | GE DCL333EA Dryer
I have a GE front loading dryer model # DBVH512EF0WW. It's about 1 1/2 to 2 years old. It has worked perfectly up until this point. When we push the start button, it just beeps twice, but does not...
heatman101
Jun 13, 2011 | GE DCVH515GF Gas Dryer
My GE DHDSR46 gas dryer won't start, what should I
505 is the thermal limit.
Looks like this:themobilian_2319.jpg
Hunt for junk and clean that out, then replace this fuse if it is bad.
See the white button to the right of the driver?
Thats the door switch, if open, that dryer won't run.
More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 07, 2011 | General Electric DHDSR46GGWW Gas Dryer
My gas dryer (3 yrs old today) wont turn. It just
O turned the drum by hand and it started running
Nov 04, 2009 | Frigidaire Dryers
My crosley gas dryer is 10 yrs old. It tries to start, I can hear the buzz. Sometimes it takes hours of tries to get it to ''catch'' and turn on. I recently changed the belt and the (?)blower wheel. Any...
when it starts does it work
if once you get it started it seems to work fine
well then you have astart winding on the motor goin bad. or done.....
try this... empty the machine
tape the door switch closed
push start and try to spin the tumbler
if it starts right up you have confirmed it
your motor is done
Oct 08, 2009 | Crosley CDG6000 Gas Dryer
Dryer not drying
MAYBE CHECK UR GAS VALVE
Aug 18, 2009 | Frigidaire FGQ1442ES Gas Dryer
Dryer has power, just buzzes, does not start to spin
sounds like you need a new motor .or PAY professional help .
Jan 28, 2018 | GE DPSB613GDWW Gas Dryer
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryers Logo
62 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
