Question about Amana DLE330RAW Electric Dryer
Heating element Hello! Just replaced the heating element on an Amana dryer model #DLE330RAW. It worked fine for a minute and now it's not heating. What could be wrong?
    Problem Solver:
  • 14 Answers
What did the original heater look like when you removed it? Was it burned in two? Make sure you are getting air circulation over the heater. Check your lint filter and air exhaust piping. Flapper outside on the exhaust pipe may be sticking.
Posted on May 29, 2008
Amana dryer dle330raw not heating
When a dryer won't heat, the most prevalent issue is the heating coil. Getting to it can be a bit of a problem, but after you do, you can check it's conductivity with a volt meter.. It's likely not passing current through, and thus not heating up - much like what happens when the eye goes out on an electric stove or the heating element in an electric oven.
Jul 26, 2017 | Amana Dryers
Will not heat up
This probably the easiest dryer to work on. The heating element is mounted on the rear left hand side and is held to the back wall with 2 screws. The limits fuses and element are all mounted on the heating element. 6dce3526-c552-4e91-8bc9-74c3ca2335ef.jpg
Sep 18, 2013 | Amana DLE330RAW Electric Dryer
Recently moved to new house. Dryer was working before, now it runs, drum turns but doesn't heat. Have tried adjusting fabric setting. Outside vent is clear and blows while running.
more than likely the heating element is not working. if there's no heat at all, this is probably the culprit. you have to gain access to the heating element to test it for continuity. no continuity=bad element=needs to be replaced. if you can get this far, then it's easy to change it out.
Jul 06, 2011 | Amana DLE330RAW Electric Dryer
Where is the heating element on a amana dle dryer
Depends on the model. Usually on the back lower left side under tub or right behind the tub in the top center. The frist location you remove the front panel to get to element and the second location the lid has to be raised up
Mar 02, 2010 | Amana DLE330RAW Electric Dryer
Super capacity Amana dryer is less than 3 years old. It no longer dries the clothes. There is no heat.
check your heating element in the back of the unit for breaks, if there is not heat that is your problem. the other issue can be a fuse that blew not letting power get to the heating element but the easiest and cheapest thing to look at first is the heating element
Jan 10, 2010 | Amana DLE330RAW Electric Dryer
Dle330raw not heating.replaced heating element was working on time dry then stopped, replaced thermostate. no heat at all now.
Check your blower, it may not be blowing hot air to your drum..You did not say if it was blowing or not.
Sep 26, 2009 | Amana DLE330RAW Electric Dryer
I have a Amana DLE330RAW everything works, but it won't heat?
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 13, 2009 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW
send me an email at b4829@yahoo.com and ill give you step by step but dont forget my four boxes here it helps my rating just ref your dryer in the e mail
Mar 28, 2008 | Amana DLE330RAW Electric Dryer
HEating element
The heating element is located in the bottom left corner. You will need to remove the drum for access. Once you have the drum out of the way, look for a square box with wires attached. There are 10mm fasteners that hold the heating element to the vent. Rome the screws, mark the wires and positions then remove the heating element. Before replacing the element make sure the thermal fuse and the high limit switches are not faulty.
Jan 10, 2008 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW Electric Dryer Logo
164 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
