Question about Nailers 3 12" Pneumatic Air Round Head Framing Nailer Nail Gun
I have a 58-8434-4 Mastercraft Air Nailer and it fell apart while doing my deck. I couldn't find the front bolt or screw which fastens the arm to the body of the nailer and they won't do anything at Canadian Tire. I can't even order the bolt I need, also there was a steel pin about a half inch in length that fell out and I don't know where it goes.
2 Suggested Answers
  • 885 Answers
SOURCE: I have a Hitachi nv 83 nailer,the firing pin sometimes does not return all the way back in,I have pushed it in with a screw driver and it only works for a short while.Any help it would be much appreci
Are you oiling your nail gun, it sounds like it's suffering from a lack of lubrication? It doesn't take much pneumatic tool oil but nail guns have to have it to work for any length of time. If you have been oiling the gun, you may have o-rings inside the gun that are worn, broken, or blown out of place. You can remove the head and check the condition of the o-rings and see if the inside of the gun is dirty. Clean the gun up and pay partucular attention to the o-rings on the bottom half of the cylinder and piston. When reassembling the gun be sure to grease the o-rings well. If you still have the same problem you may have to rebuild the gun by replaceing all the o-rings. Unfortunately Hitachi does not make rebuild kits so you have to go to their website on an aftermarket site like www.ereplacementparts.com and order each and every o-ring.
Posted on Jun 26, 2012
18 ga. Floor nailer will not shoot fasteners
Must be oiled everyday.
Had to take mine apart....metric hex keys
And clear the jam.
Remove from air source first.
Apr 24, 2016 | Norge 18ga. Floor Nailer Flooring
Torque spec's for the fly wheel
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Cars & Trucks
Front panel on range came apart
Buy some Loctite threadlocker and put some on the screws that are coming loose. It is like a liquid plastic that prevents screws, bolts from coming loose. It stays rubbery so you can take the bolts out if you need to.
Mar 10, 2014 | Kenmore 9445 Range
Liftgate problem
ON MOST LIFTGATES AFTER A WHILE TEND TO WEAR OUT THE PLASTIC FASTENER THAT HOLDS METAL ARMS OF THE LATCH,AND FELL OF..ON BACK OF LIFT GATE THERE SHOULD BE A DOOR HEL BY SCREWS TAKE THEM OFF TO SEE IF METAL ARMS ARE CONEECTED TO LIFT GATE HANDLE..LOOK AT LATCH YOU OPEN LIFT GATE WITH SCREWS SOMTIMES THERE TOO RE MOVE TO CHECK METAL ARMS,,,MOST PARTS STORES CARRY THESE FASTENERS FOR A COUPLE OF BUCKS..
May 25, 2013 | Dodge Cars & Trucks
Fuel status bar fell iinto dash
Remove the screws to dash. Pull out cluster. Once cluster is removed, removed bolts holding front plastic cover on the instrument cluster, Once plastic is removed, you will have access to reinstall the arm that fell off.
Jun 05, 2012 | 2003 Lincoln LS
Front under skirt fell off need to know what type of bolts hold it in place
If you're talking about he 2 fasteners that hold the sides up, I used a black machine screw and a black fender washer. Trying to find the exact one was difficult.
Apr 10, 2011 | 2005 Chevrolet TrailBlazer
Instructions for changing the walking belt on my Cadence DX15 treadmill
1. Unplug the treadmill and remove the motor hood.
2. Use a permanent marker like a Sharpie and mark the roller positions on the bolt on the front roller and bolts on the rear roller- not all front rollers have this adjustment bolt.
3. Loosen the walking belt at the rear of the treadmill.
4. Remove the front roller adjustment bolt.
5. Some higher end treadmills use straddle covers that have an undermount or slide mount. If you don't see staples or bolts on the top of the cover, do not pry them up. If you do have one stapled or screwed down, use a flat head screwdriver or similar instrument, pop the plastic deck cover on the right hand side up (if you are standing on the treadmill like you are using it, the deck cover on the right side). If you see screws, simply unscrew and remove the screws. Screws are included to reattach the cover near the end of installation.
6. Remove the deck boltsmost have 3 or 4 bolts.
7. Once the deck is loose on the right side, completely remove the screws from the rear roller. Be careful with the plastic endcaps. The endcaps and the roller need to be removed in this step.
8. One person should hold the deck up and hold the front roller in position near the pulley while a second person removes the old walking belt (some models that do not fold and a very few number that do have a side handrail on the right side that attaches at the base of the treadmill…if yours does, remove this handrail before removing the belt). If you are talented, you can do this with a single person.
9. With one person holding the deck up and holding the front roller in position near the pulley, the second person should reinstall the new walking belt. Once the belt is in place, raise the deck up again and look underneath to make sure the belt is in the center of the belt guides that stick down from the deck underside. When tensioned, the belt guides should make the outside edges of the walking belt turn toward the center of the belt.
10. Replace the rear endcaps and rear roller and start the rear roller bolts. DO NOT TIGHTEN THE REAR ROLLER BOLTS IN THIS STEP.
11. Refasten the deck bolts. Go ahead and tighten the deck bolts fully in this step.
12. Refasten the front roller bolt and return it to the marked position (it was marked in step 2).
13. Replace if you have undermount straddle covers or fasten the plastic side deck cover with the enclosed screws if yours were screwed or stapled down. Removing the staples in the deck with a pair of pliers before reattaching the deck cover is not required but will make it easier to reattach.
14. Retighten the walking belt to the marked positions on the rear roller bolts.
15. Check the walking belt for proper tension by lifting it 2” to 3” in the center of the belt.
16. Test the treadmill for slippage and make adjustments (if needed) for lateral centering or tracking.
17. Once the belt tests good, replace the motor hood.
Feb 17, 2010 | Exercise & Fitness
Need to know how to replace lower control arm
LOWER CONTROL ARM
REMOVAL
1) Raise and support vehicle. 3) Remove the steering knuckle.
Remove the bolts fastening the power steering cooler to the front suspension cradle crossmember reinforcement (Fig. 21). 5) Remove the lower control arm rear bushing retainer bolts located on each side of each lower control arm rear bushing. NOTE: The bolts fastening the cradle crossmember reinforcement are of three different thread sizes. Note the location of the various sizes.
6) Remove the bolts attaching the cradle crossmember reinforcement to the front suspension cradle crossmember (Fig. 22). Remove the 2 bolts fastening the reinforcement and rear of cradle crossmember to the body of the vehicle. Remove the reinforcement. 7) Remove the pivot bolt attaching the front bushing of the lower control arm to the front suspension cradle crossmember. 8) Remove the lower control arm.
Sep 25, 2009 | 2006 Dodge Caravan
Remove front axle on 2000 ford excursion
Please follow the complete steps as provided bellow.
1. Before you remove anything off the truck, measure the pinion on the front and rear axle differential. Make sure to record this measurement as we will want to put each axle back to this angle after the suspension lift kit is installed. This is especially important for the front axle. Putting the front axle back to the same measurement will keep the stock camber and caster.
2. Jack up the truck and place a jack stand under the frame on each side of the truck. Jack the truck up enough so that the front tires are just barely off the ground. Take a motorcycle strap and wrap the strap around the differential and to the frame. This will help keep the axle in the general proximity while the factory suspension is removed and the 4 link is installed.
3. Remove shock absorbers, coil springs, swing arms, rear swing arm pivot, and sway bar.
4. Use a ¼”drill and drill out the centre of the rivets that hold the coil brackets to the frame. A couple of the rivets you may not be able to drill. Next, use a cut-off wheel, grinder, or rivet buster to remove the heads of the bolts. You can use a torch, but it will be more difficult to punch out the rivets. Chances are you will have to use a grinder and grind the **** off the rivets flush with the stamped part.
5. Locate upper bag mount and drill out the four 3/8” rivet holes in side of the frame to ½” Bolt the brackets to the side of frame using the four ½” grade 8 bolts. Make sure to check the back side of the frame for brake lines, fuel lines and on the Excursion, heater lines.
6. Locate rear trailing arm bracket and fasten to the frame using the ½”bolts provided. You will first have to remove the factory transmission cross member. It will be required to drill the (4) holes in the bottom of the frame. Be careful not to drill into any fuel lines. After you fasten the two brackets to the frame, install the new cross member. Fasten into place using the 5/8” bolts. Fasten the transmission into place using the factory nuts.
7. Locate the lower air bag mount; position this part on top of the axle. On the passenger side you will need to drill a ½” hole in the flat part of the axle. There is no drilling on the drivers’ side. Fasten into place using the 14mm metric bolt. If you use the factory bolt, it will need to be shortened about ½”. Locate the cross member that connects the two bag mounts in place. Fasten using the ½” x 1 ½” bolts.
Step 8. Locate the upper and lower trailing arms. Install the arms so that the upper arms are the same length and the lower arms are the same length. Try and install so the pinion angle is close to original.
Thanks for contacting www.Fixya.com
Aug 27, 2009 | 2000 Ford Excursion
Driver side lower control arm, striped bolt.
can you email me a picture of the area ur talking about? blue_dragon45801@yahoo
Jun 26, 2008 | 1995 Volkswagen Golf
Nailers 3 12" Pneumatic Air Round Head Framing Nailer Nail Gun Logo
332 people viewed this question
Top Nailers Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Nailers Tool and Hardware - Other Expert? Answer questions, earn points and help others
