Question about Epson Perfection 1670 Flatbed Scanner
The scanner light on my epson 1670 fluctuates in intensity during scans which produce darker bands across printouts
    Master:
  • 388 Answers
Check the power souce is conected properly it may be the bulb or pwer converter inside cheapest fix is to replace the whole unit.
Posted on Oct 06, 2010
I unplugged my epson perfection 1670 scanner because my my mac said it was not connected--now when I scan something there is no image--just some lines--how do I correct this?
try uninstalling the drivers and then reinstalling them if it doesn't work you will need to replace the lamp in your scanner for information onthis go www.epson.co.uk/support
Jul 13, 2010 | Epson Perfection 1670 Flatbed Scanner
I keep getting an error that reads "unable to write to file". It was working fine and now I get that error about every 3rd scan.This is on an Epson Perfection 1670 scanner.
Just check if you have enough space where you are directing the scanning software to save the scanned images. You may be running short of disc space.
S. Mohan
Nov 04, 2009 | Epson Perfection 1670 Flatbed Scanner
We have plastic form to scan slides, no matter where we put it the preview on epson 1670. help
you will need to clarify your problem, that does not make sense.
make sure you have the proper slide adapter and check your twain settings for the right settings.
Nov 01, 2009 | Epson Perfection 1670 Flatbed Scanner
Epson Perfection 1670 Scans but produces blank (white) page/ scan
You are correct. The electronics only allow the bulb a certain amount of time to come up to full brightness, if not. all sorts of weird things happen.
Oct 10, 2009 | Epson Perfection 1670 Flatbed Scanner
Epson scanner 1670 scans a blank page
I can not copy scanned pictures from my epson perfection 1670 scanner from windows xp. Everything works from taking the scan and putting into a folder to be copied. When I bring this folder up to copy a blank 4"x4" or so window shows. I've used this scanner for 2 years or more and have had no problems till now.
Mar 15, 2009 | Epson Perfection 1670 Flatbed Scanner
Computer says there is no document on scanner
In this case Try to Do a Wia scan i will tell u how..........
Windows Vista: Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............
If it doesnt scan and does the same thing it insists that there should be a Problem with the scanner.........
If that works..........
Software Problem.............
Uninstall and Reinstall the software................
Good Luck..................
Jan 26, 2009 | Epson Perfection 1670 Flatbed Scanner
Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
1670 no image scan
Same Problem (WinXP System). I found leaving it off when not using it fixes my problems. (Its like the scanner light overheats or overloads the light receptors and it just sees white from then on, no matter what you do on the pc side of things). Other problems while stumbling into this "fix" include WIA drivers loaded which will stop scanner working properly, and finally scanner drivers seemingly working when USB cable in connected to another port other than what it was installed on but no image is shown (Not 100% sure if it was same problem as detailed at top)
Feb 08, 2008 | Epson Perfection 1670 Flatbed Scanner
Epson Perfection 1670 Flatbed Scanner Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
