Question about Linksys Wireless-G Range Expander (WRE54G)
I get linksys signal from my expander, but it says limited access. What should I do?
  • Linksys Master
  • 7,733 Answers
Try Linksys Support http://www.linksysbycisco.com/LATAM/en/support/
Posted on Oct 07, 2010
I have a M10 Valet. 2 computers downstairs have excellant signal while computer upstairs has low signal. Is there an exspander that works with the Valet
You can get a Linksys Access Point (WAP) to entend the signal.
Expanders do not work too well.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Linksys by Cisco Cisco Valet Plus Wireless...
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    What brand of signal booster will fit on the Westell 327W?
    You can use the range expander from Linksys model WRE54G v3 it works with any wireless access point and router.
    Dec 27, 2010 | Westell Wirespeed VersaLink...
    Cannot access Wireless-G Range Expander (WRE54G) from my PC using the IP address 192.168.1.240. I have tried to reset the expander multiple times and still not able to access.
    If you're connected to the expander then go start-run type "cmd" and hit enter, then in the black box that opens up type "ipconfig" and hit enter, the line that says default gateway will be the IP address of the expander.
    Otherwise there should have been a cd with it that has a utility that scans the network looking for it, I know netgear do one but I'm not sure about Linksys. Let me know how you get on.
    Oct 29, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Can the Linksys Wireless-G WGA54G 802.11g/b be used as a wireless signal booster?
    NO. you can connect a computer or a gaming device to the Gaming adapter.
    You can not use this gaming adaprter to boost the signals. you can use range expander WRE54G
    click here for more info about routers and network
    Jan 11, 2010 | Linksys Wireless-G WGA54G 802.11g/b...
    I need to expand my att dsl coverage with an range expander but don't know which one to use. I have a 2wire modem but can't get an answer from ATT about which range expander to use or where to get it
    Linksys makes a simple range expander you can use. Most expanders do not need to be connected to the network by a data cable. Just put it within range of your main access point or wireless router, and it "bounces" the signals out to remote wireless devices.
    Try the Linksys WRE54G ($70-$100)
    Jun 16, 2009 | 2wire 2700HG-B Router (2700HGB)
    Intermittent/non-existant connection with LinkSys WRT54G router
    I would get a Range Expander... it sounds like you are having problems recieving a constant signal. When you do get the range expander plug the Range Expander halfway between you upstairs computers and your downstairs where your router is at. I hope this helps!!
    Sincerely,
    cdixon18
    The ManInsideTheMachine
    May 19, 2009 | Linksys Wireless-G WRT54G Router
    I am trying to hook up a omni antenna to a wrt54g is it possible in a motel setting
    Hi there If u have a linksys wrt54g router. the omni antena will not give u the maximum wireless signal if u are going to set it on a motel, u need to setup a wireless access point in order to broadcast the signal or to repeat the signal u need a wireless access point and the model # is WAP54G..
    here is the link just incase u want to know more about on how to set up a wireless access point
    1. How do I configure an access point as a wireless bridge?
    http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4194
    2. How do I configure an access point as a wireless repeater?
    http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4200
    3. How do I configure an access point as an access point client?
    http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4202
    4. How will I know if an Access Point is configured as an Access Point?
    http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4165..
    check this out and i hope this will solve ur concern..
    Apr 04, 2009 | Linksys Wireless-G WRT54G Router
    Linksys WRE54G WIRELESS 802.11G RANGE EXPANDER Range
    The actual max distance of the range expander is about 50 feet, and sorry to say but it cannot bounce the wireless signal from it on a wall....
    Jan 25, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Wireless Network
    You can get a Wireless Range Expander to repeat the signal of the router and Linksys also has that the model is WRE54G it will solve you signal problem...
    Hope that helps........
    Jun 27, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
    Linksys Wireless-G Range Expander (WRE54G) Logo
    115 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
