Question about Electrolux Lux 7000 Bagged Canister Vacuum
Full bag light will not shut off, even after replacing with a new bag and that includes the other filter on the back. I have a lux legacy vacuum cleaner and its less than a year old. Is ther some kind of reset button or something.
  • 694 Answers
First, make sure the dial on top of the machine is set at the half way point. If it is, and there's a lot of fine dust in your area, try turning the dial so the large dot aligns with the arrow.
If it's less than a year old, actually less than 10, the warranty is still in effect (unless generic bags are being used). The best thing to do is call the store or consultant you bought it from and talk to them. They can pick it up, or you can take it to the Aerus Electrolux store for repair. They will also gladly answer any questions you may have about the product. It's a great machine, and investment, and needs proper care to get the most out of it.
Make sure you take your "sales agreement" with you.
There are things that will void the warranty. Using commecially, vacuuming liquids, using generic "made to fit" bags (genuine bags have "Home Solutions" printed on the top), buying on-line (E-Bay). Check your manual for others.
To find an authorized dealer near you, go to http://www.aerushome.com/storelocator/, type in your zip code, and click on "view dealer list".
Posted on Oct 07, 2010
Lux Legacy vacuum cuts off every few minutes. It comes back on almost immediately. It has new bag and after filter and is not clogged.
Check filter door cover is on tight, latch is locked. This happened to me with another brand.
Feb 07, 2015 | Filter Vacuums
What is the difference between the electrolux lux 7000 and the electrolux lux legacy
different motor,the legacy does not have a filter,but the same bag...one is made of a light metal [legacy] the other a polycarbonate plastic. Chris
Jun 24, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Aerus Lux 7000: the full bag light keeps coming on but the bag is not full.
Electrolux uses a pressure differential control valve. This valve measures air before and after the bag. There is a orfice or small hole where the hose connects to the vacuum cleaner, and a orice at the back of the bag canister. As the bag fills up the suction pressure reduces at the hose connection and increases at back of the bag canister. When this happens the control valve has a diaphram that closes, which shuts the vacuum off and gives you a full bag light. There is a thin plastic flange that prevents an o ring on the control valve stem from coming off. The flange breaks, the o rings comes off the stem and the vacuum will shut down indicatiing bag full. The after market price is about 22.00. The valve is easy to replace if you are familiar on electrolux vacuums. When I replace these valves, I use epoxy two part plastic putty on the flange of the valve. It takes 2 days to cure, but the flange will not break.
Jun 25, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Full bag light on when bag is new
Check for secondary filter, if it is clogged could cause bag light to come on as suction is dropping due to filter, not bag.
Dec 08, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux 5000 put in new bag but when i turn on the
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Oct 25, 2009 | Electrolux Lux 5500 Canister Vacuum
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux legacy
Actually the problem is inside of the canister itself. You need to change a part called the control valve. Occaisonally when fine particles get inside of the valve it damages the inside of the valve, sending a false reading to the main motor, causing it to shut off. This is a relatively quick and easy repair and should be recieved on a same day basis.
Oct 20, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Lux Legacy shuting off by itself
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
hope this helps
May 10, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Aerus lux 5500
Hi.
Check & replace any filters that are fitted to machine.
Replace bag with new,
Clear hose of any foriegn items & check floor tool for blockages.
http://dysonmanuals.llc.nu/
Chris..
Dec 18, 2007 | Electrolux Lux 5500 Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
271 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
