Question about Frigidaire Washing Machines
How do you get the back of the washer off - Frigidaire Washing Machines
    Genius:
  • 1,028 Answers
You don't ..remove 2 screws at base of front panel but first lift top by pressing in clips under edge of top about 2-3 inches from each corner
Posted on May 29, 2008
How do the clips go back in the back of the washing machine model
If you are referring to the brass colored clips, follow these steps:
1. With the lid of the washer casing open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame base in the front.
2. Lower the washer casing back onto the side frames. Make sure the small cleats on the side frames fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
3. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you to seat it.
4. Reinsert the brass clips. Place the 90 degree bend of the clip into the slot on the back of the washer first, and then forcefully push the J-hook end of the clip down into the opening on top of the washer. NOTE: Once the clips are snapped back into place, the washer case should fit tight and not move on the frame.
5. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
6. Reinstall console.
I mention all these steps to ensure you have the washer case back on the frame correctly, and the back panel is seated as well. If not, the clips will not insert properly and the washer will rattle during the spin cycle. Step 4 refers to how to correctly install the brass clips. Remember to insert the 90 degree end of the clip into the BACK panel slot first. Then, push the J-hook end of the clip down in the opening on the top of the washer. You may have to use a little force. Once it snaps back into place the washer case should fit snug. If you still have questions, please let me know. I hop this helps you.
Feb 05, 2010 | Washing Machines
Model #110.26901691 Kenmore washer. Need to
The end caps come off by placing your hand over the TOP of the console and lifting each one from the back and pulling forward. If you can't get them to come off by hand, try placing a screwdriver in the top groove in the back and give it a twist to pope the cap free. Once the caps are removed follow these steps:
1. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
2. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
3. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
4. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If you are replacing the lid switch, you will now have full access to remove it from the under the washer casing.
To reinstall the washer case, follow these steps:
1. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions about this repair, please post back and let me know. You can view some excellent exploded view diagrams of your washer at searspartsdirect.com for assistance in locating parts if needed. I hope this helps you.
Dec 08, 2009 | Microwave Ovens
How to install the rear clip on the whirlpool washer lsr9434pq4
Follow these steps:
1. First, make sure you have the washer casing seated correctly on the frame. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
3. Reinsert the brass clips by placing the 90 degree bend of the clip into the slot on the back of the washer first. With the clip inserted on the back panel, forcefully push the J-hook end of the clip down into the opening on top of the washer. The clip should snap back into place and the washer casing should fit tight against the back panel and frame.
If you have any questions, please let me know. I hope this helps you.
NOTE: Each clip has a 90 degree bend at one end, and a j-hook end at the other. The 90 degree bend fits into the back panel slot, the j-hook fits into the top panel. Make sure the clip is properly oriented, or it won't fit properly.
Nov 12, 2009 | Whirlpool LSR9434PQ Top Load Washer
Kenmore 600
These washers are not designed to have the back panel removed. They are designed to have the entire cabinet come off in one piece. Its a failrly simple procedure. Just follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console
does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp the case under the front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
NOTE: o reinstall the back panel correctly you will need to pop the case loose from the frame and reinstall. That's why I included all these steps.
Read through everything thoroughly. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
Oct 28, 2009 | Washing Machines
How do I remove the back on my Kenmore 70 series washer?
The back doesn't come off on these model washers. You need to remove the entire exterior case to access the interior components. Just follow these steps:
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
Its not as difficult as it seems. If you have any questions about these procedures, please let me know. I hope this helps you.
Sep 25, 2009 | Washing Machines
How do take off the back panel
The back panel does not come off on a Whirlpool top loader. These washers are designed to have the entire washer casing lift off to access the interior. Just follow these steps:
In order to place the washer case back on the frame, follow these steps:
1. Re-install washer case. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
I know it seems like a lot, but this is how these washers are to be serviced. If you attempt to pry the back off, it will damage the washer and may cause the case to become unseated and vibrate violently during any spin cycle.
If you have any questions, or require additional assistance, please let me know. I hope this is helpful to you.
PS I'm assuming there is a reason why you are wanting to remove the back of the washer. Can you describe any symptoms of problems you may be having? I can give you advice on how to repair if needed.
Aug 22, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have model 110 24642300 top load. took the back
Actually the washer should have come apart by removing the outer casing while leaving the back in place on the frame. The following steps explain how to remove the casing and reinstall:
1. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
You may try going through these steps and make sure you have the back of the washer correctly in place on the frame prior to reinstalling the case. It may sound like a lot, but this is actually the proper (and easier) method.
Jul 29, 2009 | Washing Machines
Can't get the case back on the washer kenmore series 70
Follow these steps:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
If you are still having problems at this point, please post back and let me know. I hope this helps you.
Jun 12, 2009 | Kenmore 22422 Top Load Washer
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Apr 05, 2009 | Garden
Remove control console and case on whirlpool wtw5900
To remove the washer console and casing, follow these steps:
2. Remove console by sliding a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
To re-install the washer case:
4. Reinstall console by placing the pastic tabs on each end into the grooves on the top of the washer casing. Place the back tabs in first and push the console down until it snaps back in place.
If you need further assistance please post back and let me know. I hope this helps you.
Jun 17, 2008 | Whirlpool Washing Machines
Washing Machines Logo
37 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
