Question about Garden
Have a craftsman microtork torque wrench the handle broke and am having a hard time getting the new one on any sugestions
    Sergeant:
  • 268 Answers
Go to Sears with make, model, & broken torque wrench and they usually will replace for free or at least be able to order you one.
Posted on Oct 06, 2010
Handle came loose on my craftsman torque wrench. What is the proper way to replace it? I noticed that the nut on the inside came loose. If I re-tighten the nut will it effect the torque calibration? I
I had this problem with mine as well. Most are threaded into the case and don't have nuts inside. I took each bolt out one at a time and cleaned and coated with Blue lock tight and torque back in to factory spec. Just get them snug don't over tighten. Do one at a time so it doesn't come apart. I would have tool recalibrated or at least check it behind a known good torque wrench
Nov 12, 2014 | Craftsman Professional -torque Tested -...
The ratchet on craftsman microtork torque wrench 44593 does not work
The ratchet pawls have seized and a ratchet rebuild kit is needed.
Jul 20, 2014 | Craftsman Microtork Torque Wrenches -...
Craftsman instructions
You can not use that model for the torque you require. A larger capacity torque wrench will be needed.
Jul 16, 2014 | Craftsman Microtork Torque Wrenches -...
How do i get more torque out of my craftsman impact gun?
buy a better gun the cheap ones dont have any power
Feb 22, 2013 | Craftsman 1/2" Impact Wrench
How do I determine how much torque my impact wrench makes?
I test my impact wrench on a good vice and with a high grade steel nut/ washers and bolt that can take high torque. Select bolt with thread almost to the head. Hold head of bolt on solid vice and place two washers(more if needed to reach into threaded area) and nut on bolt. Set air pressure to max (I have 125psi). Run nut against bolt head with impact. Remove nut with torque wrench for reading. This low tech method will give you a rough idea. Higher pressure may give you better result. If you have used your air wrench for a while. Clean by adding diesel fuel into air fitting. Little at at time until diesel comes out rather clean. Then add a few drops of oil. Then test again. Good luck.
Aug 17, 2011 | Craftsman Tools 1/2" Air Impact Wrench...
Broke the screen on my craftsman torque wrench
It is likely that your wrench was made outside the US soparts may not be available but you might enter your tool number on Sears Partspage to see if it comes up:
SearsParts
May 16, 2010 | Garden
How to remove blades on craftsman lt2000
There usually bolted on from underneath you must have a wrench are set of wrench to take off. Most models are some times kinda hard to get to
Sep 29, 2009 | Craftsman Garden
Craftsman Ride-on hard start, loss of power
you have to get piston to top dead center, there should be 4 thousandths of clearance between rocker and valve on both valves.
use two wrenches to tighen
Sep 02, 2009 | Craftsman Garden
1/2 air impact wrench will not turn socket. Air just comes out the small vents on the bottom of the handle. Any suggestions?
Make sure the fitting are tight on the hose and gun. Also make sure that the switch for forward/reverse is solidly in one position, if it is not it will cause what you described.
Jul 09, 2009 | Craftsman Tools 1/2" Air Impact Wrench...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
