Question about Humax HFA100 DTV Receiver
My humax set up says lnb short what next? - Humax HFA100 DTV Receiver
HUMAX PVR9300T moved it to another TV, WHEN I TURN IT ON IT GOES FOR A MINUTE OR SO AND THEN GOES OFF AND STARTS TO RELOAD. iT DOES THIS CONTINUOUSLY
It's just searching for signal make sure that all the lnb inputs are securely fastened as you could have pulled it a bit just check on the pvr lnb in
Apr 05, 2017 | Humax Televison & Video
My sky dish as 2cables ,my humax 1000 as1 connection.which one do I Use
Does not matter which one you use as they have their own connection to the lnb
Nov 04, 2016 | Humax Televison & Video
What does lnb short mean
the cable may have went bad or receiver, but check or replace the cable first
Jul 28, 2016 | Televison & Video
Ikonvert TV converter box is reading lnb short what is this
'LNB' is low noise block. It is the receiver that is located in the middle of your satellite dish where the signal is collected from the dish.
You need to check the wiring at the rear of the receiver and all the way to the LNB itself.
images of LNBs
Go to Bing homepage
Jul 18, 2016 | Televison & Video
Humax free receiver only give horizontal not vertical polarity
change your LNB, this has 2 small antenna's inside. If the receiver only receives one and not the other, the Lnb is more then likely the culprit in the setup.
Apr 11, 2016 | Humax Televison & Video
I have a foxstat -HDR humax box and I am getting no or bad signal on the TV downstairs. I can get some channels but not all.
I suspect that the box upstairs is a Freesat box; a Freeview box requires a feed from an aerial, not a dish.
The problem you are seeing may be caused by water in the cables, if they are not sealed at the LNB. The LNB may be failing, but dish misalignment is more likely.
As there is an unused output on the LNB, try swapping one of the feeds with a poor signal to it.
Jul 27, 2015 | Humax Televison & Video
I got this message lnb short ,what can i do ?
Start at any outside exposed connection of your Sat cables. They get water in them in the bad weather. The "Barrel" F connector then needs changing and dry out the mates. Sloppy installers do not put in "Rain Loops" (a loop below the connection so water runs down to loop to drip instead of runing into the connection), rubber boots, or Silicon protective coatings at the connections. 4 way Diseqc supplied with STB should have caps on the unused ports to keep moisture out. Good luck.
Dec 16, 2009 | Humax HFA100 DTV Receiver
Changed from single to twin LNB, no signal
HELLO
Here is a suggestion! Try SKEWING the LNB around a few degrees. Looking at the front of the dish, turn your LNB to the LEFT slightly (that is anti-clockwise).
Sometimes it's the little things that matter most where installation is concerned. It is also possible that due to the weight of the new LNB, the alignment may be out.
Nov 21, 2009 | Fortec Star Lifetime ULTRA
Humax HFA100 DTV Receiver Logo
199 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
