Question about Sharp AL-1551CS Printer
I have L1 in display it vent from H4 after reset
I have L1 in display it vent from H4 after reset to L1 any solution ?
  • info63916 Oct 06, 2010
    Now it working
    thanks great jobb i nerly trows on the junk yard
    This is better than NASA
  • 857 Answers
The error
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are two possibilities
they are :
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Posted on Oct 06, 2010
  • Jayant Jha Oct 06, 2010
    Thanks a lot please rate my answer so that i can get the credit or it, i will appreciate that.
    Thanks a lot.
My sharp ar5516 use to display h4, l1, h1, p1, u1, ch and i need the solutions to open them.
For H4 enter the following codes # interrupt C interrupt 14 Start button twice For ch check whether all the doors(side door,front door) are closed.
Jan 15, 2011 | Sharp AR-5316 Advanced Digital Imager...
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:
Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
If done correctly the display should go blank.
Then key in 14 as if you were going to make 14 copies.
Now press the "print" button
The machine should automatically shut down and restart with the H4 code being gone.
If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Sharp AR208D Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Displays H4 code
What model of copier
if sharp go to service mode
reset it with sim 14
May 02, 2009 | Office Equipment & Supplies
Showing h4
If your machine is AR-5316,
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Mar 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
L1 SHOWING ON SHARP COPYER SF756
An L1 generally means the lamp carage is not moving. Remove the glass and see if that lamp assembly moves back and forth freely or if it is hitting something in it's path.
Apr 04, 2008 | Office Equipment & Supplies
H4 Problem
Hi there, if you want to clear this code its very simple, do the following: -on your control panel locate the clear and auto exposure buttons, next -hit in the following sequence clear, auto, clear, auto without holding them down, after that all your panel lights should go out. If they do not you have to keep trying...They will go out. -Next program the machine as if your going to make 14 copies -Once 14 is displayed, hit the green start button and your copier should be working again. Cheers! :)
Sep 11, 2006 | Xerox WorkCentre XE88 Laser Printer
Sharp AL-1551CS Printer Logo
128 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
