Question about Sony PlayStation 2 (PS2) Console
The ps2 isnt reading any discs, it just says there's no disc unless i press down a little on it, even then when I move my hands it says there's no disc.
How do i get a copy of the blueprint to see this and check pattern
Posted on Oct 07, 2010
It just trys to read discs but then says disc could not be read.
It might be that the scanner in the ps2 is dusty. Try using compressed air to clean it out.
If that isnt it, check you disk for scratches or little paticles and fingerprints. Hope I help~ :D
Sep 14, 2010 | Sony PlayStation 2 (PS2) Console
There is no data, reading disc ps2
Clean the disc with rubbing alcohol. There may be scratches, which causes the Ps2 to not recognize the disc. Also, gently blow into your ps2. There may be a dust build up.
Jul 18, 2010 | Sony PlayStation 2 (PS2) Console
Slim PS2, disc not spinning
Well if there is nothing with the lens, i am afraid you're ps2's are garbage now. Your best choice is to sell it to some one, or throw it away.
Dec 09, 2009 | Sony PlayStation 2 Slimline Console
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
Will not read blue discs no problem with clear(silver) ones tho.
1. Apparently, blue PS2 discs are lighter than silver ones, so they tend to move around more when the PS2 is reading them. To fix this, you can put duct tape on the top of the disc. This will make it heavier, so it won't move around too much and it should make reading the disc easier for your poor PS2. People have told me that this indeed works (but not always). Don't go overboard with the tape though. Attempt at your own risk. 2. If the problems occurs when the PS2 is horizontal, try putting it into its vertical position. Or try putting it horizontal if it is vertical. 3. Use a can of compressed air to clean dust out of the system. 4. Make sure your game discs are not the problem. Keep them as clean as possible. Even small scratches can cause problems. 5. Open up your PS2 and clean it out or try adjusting the lens. Very risky and voids your warranty. 6. Try using a DVD lens cleaner (for problems reading silver discs) or a CD lens cleaner (for blue disc problems). 7. Send your system to Sony for repairs. Due to a lawsuit, Sony may have to repair your PS2 for free even if there is no warranty. Contact Sony for details. That is all the advice I can give. If the len(s) cleaners or compressed air don't work, then you are probably just out of luck. There is no magic way to suddenly get your PS2 working again without professional repair.
The trick to getting the discs to play on any PS@ (old or new) when they are black or blue is to put a piece of tape lengthwise and width wise around the hole in the disc on the topside (picture-side) of the disc. What this does is add weight to the disc and thus allows the PS2 to read it more accurately. I had bought many older titles not too long ago and was disappointed when they didn't work. Then I spoke with a Japanese expert online and he suggested using scotch tape around the hole in the disc and it worked instantly. Don't be fooled into buying a new PS2, just a roll of scotch tape. You'll only need four one inch strips.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 - Does not read CD
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Hi there
Hi carlosca.
You could have some lint of hair stuck under the disc drive hub. look at closely to see and get it out.
The best thing is to know that the Slim laser has a plastic lens, and it will melt. Do not leave a disc in the powered up PS2 when your not playig with it. If you leave it running with a disc in the system and it is not reading the disc well, over time the Laser will heat up and melt the lens. If you posted this, how do you not have way of getting parts online.
Go to www.playstationclinic.com and call them to ask for parts you need, they will send them to you at a very reasonable price.
Dec 11, 2008 | Sony PlayStation 2 Slimline Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Disc Read Error ( slim PS2)
Ah yes the dreaded DRE... time to replace your ps2 dude, this is the easiest and least headache solution.
Logged too many hours on those poor machines ;)
Aug 18, 2008 | Sony PlayStation 2 (PS2) Console
Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
