Question about Whirlpool Dryers
My dryer wont heat up its a model le4440xww0 - Whirlpool Dryers
  • pprisco69 Oct 06, 2010
    its electric and how do i know when useing ohm meter sorry just dont understand completely
    im in need of more explanation im tech challenged
    President:
  • 1,554 Answers
Remove the rear panel then locate the thermal cut-off on the top part of the heater canister. The thermal cut-off cuts out when the high-limit thermostat fails. These parts along with the cycling thermostat are wired in series with the heating element.
You can bypass the thermal cut-off for troubleshooting purposes if you don't have a tool for continuity testing. Tape the wires together or jump a wire between them then insulate them properly. Plug the dryer in then start it. The thermal cut-off is indeed blown and needs to be replaced along with the high-limit thermostat if the dryer heats up with the thermal cut-off bypassed. Do not use the dryer with the thermal cut-off or any other part bypassed due to fire hazards.
Do the same with the high limit thermostat if the dryer still doesn't heat up with the thermal cut-off bypassed then with the cycling thermostat if the dryer still fails to heat up.
Please make sure to accept this post if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful or non-informative it is. Accepting a solution will not stop you from communicating with the expert should you need further help regarding the problem stated herein.
Posted on Oct 06, 2010
  • 11,896 Answers
Is this gas or electric? If it is electric, then you will want to test the heating element with an ohmmeter. You can also test the power going to the heating element with a voltmeter. The heating element may be bad. Make sure the venting and all of the machine is clear of lint. Many of these units have a flapper inside the venting of the machine that closes when the dryer needs to heat up and opens when it needs to cool off; The vent can get stuck open.
If it is gas and not drying, check that there is a flame and that there is power to the ignitor and thermal coupler. A thermal fuse could be bad on both gas or electric.
  • Nate Stansfield
    Nate Stansfield Oct 06, 2010
    An ohmmeter measure continuity. By removing the wires attached to the heating element, you then place a probe of the ohmmeter on each connector of the element connector. If you have no reading or very very low reading, then it is bad. If you have a strong reading, then it is good.
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Wont heat up
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 17, 2009 | Frigidaire GLER642A Electric Dryer
KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
Mar 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Ge dryer not heating
Most likely problem is burnt out heater coils
Feb 02, 2009 | GE DVLR223 Dryers
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
207 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
