Question about Olevia LT32HVE 32 in. LCD Television
Whats wrong i turn my tv on and i dont get a picture but only sound. sometimes neither. how do iget this fixed?
  • 979 Answers
It is possible that your lamp has expired for the "no pix, only sound" problem, but the other symptom could be as simple as "wrong input selected" or another internal problem with your set...accordianman
Posted on Jul 01, 2008
I have a 50 inch Hisense TV and the picture went out but I'm still receiving sound.... Can you please help me with a fix for the problem?
It all depends what has led up to the problem, however if there has
been no indication of something going wrong,ie. picture getting dimmer, the most common fix is to reset.
First just check all cables are firmly connected. If that does not work then....
Unplug tv, disconnect from cable box, satellite box, any receivers.
Also turn power off to them as well.
Connect everything back and turn on.
Here is a video of other generic problems that can go wrong on any
tv that leads to sound with no picture.
TV Has Sound But No Picture Troubleshooting Guide
Nov 19, 2015 | Hisense Televison & Video
Tv picture turns off by itself. sound still
the problem of your LCD TV is maybe there is something loosing up when heated on the backlight board of your LCD TV......all you have to do is resolder it or reheat it with a hot air...........if you dont bring it to the sharp service center
Oct 30, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My hitachi turns on and has a red/green glow, but no picture on it. It sounds like it is running, but there is no picture or sound. It recently had a power surge go through it. What could have gone wrong...
have you checked the bulb in the tv? sounds like the bulb is no good they are around 40-60 bucks...make sure tv is off and unplugged before checking and dont touch it just look to see if its blown
Jun 04, 2009 | Hitachi 60V500 60" Rear Projection...
No picture at all, black screen, audio works , cant work menu cant see it
sounds like video problem take to tv shop they will address your problem okay good luck
May 02, 2009 | Televison & Video
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
My playstation 3 broke i dont kno whats wrong
if your using the original ps3 cord that came with it (yellow white red) then you will have to use an HDMI cord and when you do use this cord then everything will show up on your tv including sound.
Oct 16, 2008 | Sony Playstation 3 (PS3) Console
Standby Blinks 5 times. Picture goes off but sound stays on. Only hookup is Digital Cable - help!
Plug the electricity to a surge protector. I fixed my that way. Try it and let us know.
Jun 28, 2008 | Sony KP-53HS10 TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
Olevia LT32HVE 32 in. LCD Television Logo
76 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
