Question about HP OfficeJet Pro k550 Printer
Some rows won't show up. Seems every other line is perfect.
  • 40 Answers
Its need to clean your printer nozzle, go to control panel then printer and faxes select your printer then right click select properties then maintenance. just repest cleaning until you don't see missing row.
Posted on Oct 06, 2010
    Master:
  • 388 Answers
Uninsatll the printer and re-install it.
I have multirow toobar installed for firefox. Why does it show only one row?
The add-on limits the number of lines to display. To change this, select "Tools" - "Add-ons", and then click the "Options" button underneath "MultirowBookmarksToolbar".
Mozilla Firefox Plugins and Extensions
Oct 23, 2014 | Computers & Internet
Find the pattern of missing numbers
57
32 25
17 15 10
9 8 7 3
6 3 5 2 1
Apr 12, 2013 | Computers & Internet
Component input won't work
There are 2 rows of RCA connectors on the back of this TV.
If you are looking at the back of the TV, on the right side you'll find the connectors.
On the bottom row, left most RCA jack is the Video in for the Component video.
on the top row, the right 2 connectors are for Audio connections.
we put the Yellow plug from our Wii into the bottom row video connector, and the red and white RCA connectors into the top row plugs.
This enabled us to connect the Wii, and play games.
Sep 24, 2012 | Emerson LC391EM3 39 in. LCD HDTV
Engine won't crank. seems like no fuel getting to engine. Had the dealer replace the fuel relay worked for several days... replace it again myself....but still won't crank.
SOUND LIKE FUEL PUMP FAILURE FUEL FILTER LOCATED ON THE FUEL PUMP ASSEMBLY REPLACE THE SOCK FILTER IT COULD BE PLUGGED IF FUEL FILTER OKAY OR CANT BE REPLACED YOU HAVE TO REPLACE WHOLE FUEL PUMP ASSEMBLY WITH FUEL FILTER TO REMOVE FUEL PUMP YOU NEED TO REMOVE SECOND ROW LEFT HAND SEAT, REMOVE THIRD ROW SEAT,REMOVE SECOND AND THIRD ROW SEAT BELT BUCKLES MOUNTED TO THE FLOOR,REMOVE LEFT HAND CENTER PILLAR,REMOVE LEFT HAND REAR TRIM PANEL, REMOVE LEFT HAND REAR SIDE DOOR KICK PLATE AND WEATHER STRIPPING, REMOVE SECOND ROW REAR CENTER CONSOLE AND BASE IF EQUIPPED, REMOVE THE INSPECTION HOLE COVER UNDER CARPET BY TURNING RETAINER 90 DEGREES REMOVE ELECTRICAL CONNECTORS, REMOVE EVAP HOSE.REMOVE SUPPLY HOSE, REMOVE LOCK RING USING SPECIAL TOOL J - 46214, REMOVE FUEL LEVEL SENSOR, REMOVE FUEL FILTER AND THE FUEL PUMP ASSEMBLY.BESURE DEPRESSURIZE FUEL SYSTEM BEFORE DISCONNECTING ANY FUEL LINES AT THR FUEL TANK.
Jul 16, 2011 | 2004 Nissan Armada
The toolbar is not working seems like the bottom part of the screen are not working. the screen also has lines.
try screen calibration. you can find it in prefs. the lines may be because your device fell or experienced some kind of shock. if screen calibration still won't work try downloading powerdigi (it's not free though, you can try first the demo) it calibrates screen almost perfectly! :)
Try cleaning the sides of the screen using cloth or thin paper to remove dust. accumulated dust may cause the lines. if not, ask for repair centers though it is very costly.
Jan 23, 2011 | Palm TX Handheld
I had a vertical line on my laptop screen
A line on a LCD screen (like a laptop) is caused by a faulty power connection in the screen.
Usually a entire row or column will not activate causing a black line to show. When you closed your laptop, the screen is powered down. When you opened it back up, the screen would be reinitialized and it appears that you lucked out on your issue.
When a row or column fails it is usually a permament failure that can only be fixed by a monitor technician or a screen replacement.
A similar failure can happen that causes black dots to show on the screen. These are burnt out junctions where the rows and columns meet together. The dot is commonly called a pixel.
Jan 21, 2010 | Compaq Presario M2000 Notebook
Horizontal lines on 42" vizio LCD
i have the same problem. any solution
Dec 21, 2009 | Vizio VW42LF 42 in. LCD HDTV
The last row of icons on my iphone won;t work. Help....
The last row of icons which is the bottom row with Phone iPod etc?
It sounds as though your digitizer is bad, the iphone digitizer is delicate and seems often goes bad.
does your unlock screen work?
the bottom off the screen handles the unlock and bottom icons.
if your unlock switch works then you may just have a software problem going on.
reboot your phone by pressing and holding the power and home buttons until the apple appears.
when it reboots see if it works properly, if not you may have a bad digitizer.
is your iphone a 2G or a 3G?
Jun 03, 2009 | Apple iPhone Smartphone
Front Panel (LCD screen) only shows black boxes
From what I am reading, Try this.
Go to Xerox.com,
then click support and drivers.
Enter phaser 6100 in the search box.
Then once at the 6100 options, click drivers and downloads and then download the Firmware version 1.05 and reload your printer software.
May 04, 2008 | Xerox Phaser 6100/BD Laser Printer
HP OfficeJet Pro k550 Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
