Question about Peavey Audio Players & Recorders
I have a Peavey Valve King 112. When I plug in my guitar I get nothing.The power light is on and the preamp is on as well.There is just silince.No humming or crackling.
  • Scott Frye
    Scott Frye Oct 07, 2010
    HI....
    Do the 2 power tubes ( inside the cage) have the filaments lit up?
    Can you try another speaker on it?
    This model has some board mounted fuses too. which requires taking the amp out of the box
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
This could be anything. You could try swapping the preamp tubes. If it were a power amp tube problem, it is likely the mains fuse would have blown, Since the pilot lamp is still on, we will assume that the problem is at the preamp level. This absence of signal can be caused by a dead tube, or more complexly, by a faulty resistor or capacitor in the signal path. If you can't resolve the problem by swapping preamp tubes with a known good one, you should take the amp to a tech experienced in servicing tube guitar amps. Any good tech should be able to sort this out within an hour of labor time. I doubt it will require any expensive parts. It may even be as simple as a loose/bad connection, either from manufacturing, or from normal use. Pro tube amps are subjected to levels of heat, vibration and electrical stresses that consumer electronic gear never sees.
Posted on Oct 07, 2010
What are the settings on a Peavey TransTube Series Studio Pro 112
Actually they are all subjective depending on what is connected and what you want to hear. Reading the manual will help. try this link: http://assets.peavey.com/literature/manuals/80302311.pdf
Jul 21, 2014 | Peavey Audio Players & Recorders
6505 +112 has a bad hiss with nothing plugd in
Some hiss at high gain settings is normal. If you get objectionable hiss at 1 o'clock settings of gain, that is too high. Electronics has noise that is "statistical" in nature due to physics that we can't get around in design. Most hiss is created in the preamp area and swapping tubes in the first stage might help. By varying the volume controls and observing the level of the hiss, we may be able to analyze the offending staage of amplification. ALso turning up the treble controls will increase the hiss, as it is mostly in the higher pitches.
Jun 26, 2011 | Peavey 6505 Plus 112 60w All Tube Combo...
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
Peavey 5150 II guitar amp! Power Tubes don't light up and only
peavey 5150 II has low humming sound but still plays and sounds pretty good...should i re-tube it?
Jul 18, 2009 | Peavey PV-3800 2-Channel Amplifier
My amp won't play distortion.
Hello all you have to do is turn your master volume down to just barley on then turn your pre amp volume somwhere about 2:oclock depending on how much distortion you want ajust your volume on your guitar a little past halfway to give yourself some headroom in case you need to turn up some while you are playing! just think of it as your guitar is your first pre-amp then your amp is second preamp in line ,that is your over drive ,then the master volume is how loud you want the overall volume i hope this help's ya!
Dec 26, 2008 | Peavey Audio Players & Recorders
How can I download a new owners Manual for my amp?
You can go to Peavey.com, support and seach manuals or go to: http://www.peavey.com/search.cfm?c=3&term=Ecoustic+112
I hope this helps and if it does would you mind rating the solution. Thanks
Nov 30, 2008 | Peavey Audio Players & Recorders
1,202 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
