Question about Canon Cameras
Canon EOS 400D - Error message - There is a problem with your CF card- needs replacing. We have original card and also replaced with new card - message keeps appearing. What else could this mean?
    Brigadier General:
  • 11,967 Answers
Look inside the card compartment to check for broken or bent pins. Have you tried formatting the card in the camera? This will erase it so download any pictures first using a card reader if necessary.
Posted on Oct 07, 2010
How do you replace a cf card on a canon eos 400d
see the instructional video and proceed with common sense and logically. God bless you
Aug 02, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d error 99, shooting not possible. turn the power swithch on off again or re-instal the battery. It has been doing this for a long time and nothing is working to fix it! Thank you,
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 400d service manual link:
http://goo.gl/LHYVAy
it will help you to save a lot of money
Hope it helps, Thanks
Oct 22, 2010 | Canon EOS 40D Digital Camera
My Canon Rebel xti camera states that is an error with my compact flash, I bought a new one and it still won't work
Pull the cf card out and with a careful eye (maybe a small flashlight and magnifier) look down the slot and check to make sure none of the cF card receiving pins are bent... it happens and it'll give you a card error. Regretfully if this is the case, it'll need a repair, replacement parts are available but it is a little techie to get apart and swap parts... Check the pins... good luck on this..
Sep 08, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Camera message:there is a problem with CF card
try formating the card on your PC using the canon software, & then reformat it in the camera, it will work
Aug 21, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Problem with the CF card
Do both of these CF cards still function when you connect them to the computer?
Inspect the CF connector on the camera using a flashlight (torch). It's possible that one or more pins on the connector may have been damaged, somehow. If this is the case, the camera will need to be repaired.
Can you still operate the menus after the error message appears? If so, use the menus to reformat the card (see the manual for instructions).
Aug 08, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D dslr will not work various CF memory cards. Error message ( replace CF card)
Using a flashlight, check thru the CF memory card reader if there are some pins that are bent, missing (broken) or damaged.
If this is the case, it is necessary to have serviced the camera to replace such pins, and inspectd for the broken pin pieces that may be stuck inside the camera, and cause later a short circuit.
If all the pins are in good conditions, may be the internal memory reader circuitry is failing, which requires also a professional camera repair service.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform the steps to repair it.
If so, You will need tools to do it, which includes the usage of a soldering iron, microscope (since requires micro soldering), and buy the CF memory card reader connector..
Best regards,
Apr 02, 2009 | Canon EOS 400D Digital Camera
Canon eos 400d. card empty but cf light flashes red
Hi! Rachel, Mark here see if i can help.
Try different cf card see if it works.
Next if that worked or not take cf card place in computer & format card. Retry in camera.
Hope that fixed ya if not comment back me happy to assist you further. Good Luck! please rate.
Mar 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
CF Card
Please post back the error message you notice.
Mar 22, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Cameras Logo
239 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
