Question about Plumbing
I have a replacement cartridge to fit to a dripping Vitra - Atlas - basin mixer tap. How do I do this?
3 Suggested Answers
  • 171 Answers
SOURCE: mixer tap on the kitchen sink
Hi gt_elijah.
I'm Harvey the Master Plumber.
You want to know if there any way to tighten a faucet on a kitchen sink?
Yes! All faucets have to be secure, but there are as many diferent methods as there are diferent manufacturers. If you are unfamiliar with the diferent methods then you might not recognize the screw, nut, bolt or fitting when you look at it. Also, for many, a special tool is required. It might be wise to have someone local look at it.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 44 Answers
SOURCE: need to fit ideal standard lever cartridge to mixer tap
hi you 1st need to isolate both hot & cold water supplies to bath.lift the lever up & underneath the lever you will see s screw unscrew it & be careful not let it go down the plug hole, so a good idea at this point is to put in the plug!!!
Once the screw is loosened you will be able to remove the lever.
then there is a cover which will need to be undone & removed seeing as its gold you will have to be careful undoing this as it may be stiff, sometimes a few taps with the endle of a srewdriver handle will loosen it enough so you can remove it. once this is removed you will gain access to the hexagonal part of the cartridge, so yo uwill need to have the appropriate spanner or adjustable spanner. you will need to hold against the tap when undoing it so as the whole tap body doesnt move.once the cartridge is removed the new unit can be fitted in reverse order.it sounds simple but being Gold you have to be careful you dont damage it whilst attempting to remove the old one. Tip put some silicone gtrease around the o rings on the new unit as it will make it easier to remove if you ever have to remove it again?
Kindly
Richie
Posted on Dec 15, 2008
I turned on the tap and a grey filter and a yellow disk fell into the basin from the spout of the tap. I am unsure if another part went down the plug hole!
Contact Reece plumbing or take parts into Home Depot or Lowes and see if they can tell you what you need
Nov 26, 2015 | Food Mixers
I have a vitra pure mixer tap and can't get into the tap
Could you take a few pictures of the tap so that we can find out the place you should start with?
Dec 20, 2013 | Plumbing
Fix a quater turn mixer tap Aumix
change the cartridge...shuld help
Dec 04, 2013 | Plumbing
Air in bathroom cold water pipes
You have to install anti knock pipes into your plumbing, it's quite common. Go to the local home center you can by pre made or make your own as I did when remodeling my basins. Good Luck..
Oct 20, 2012 | Home
I have a vitra minimax mixer tap needing a new cartridge. The problem is how to get into the mixer to change the cartridge - any advice on how to get into the tap much appreciated.
I've just done this. It is much the same as stated above. Isolate the water by turning the service valves below the sink 1/4 turn (Off). They look like flat-head screw heads or may have levers on (usually red & blue). Open the tap to check & drain the water in the tap. Below the tap handle there is a little round cap with the (red & blue) hot/cold indicator. This is plastic, so carefully prise it out (plug the sink first!). Now you can insert a 2.5mm Allen key in the hole and loosen a grub screw - you shouldn't need to remove it, just enough to release & remove the lever head. Next, unscrew the domed top. I used duct tape for extra grip as there was a bit of limescale. Now the Hex bolt is exposed. You need a 32mm spanner for this. Maybe grip the tap to avoid damaging it or the sink. Under the bolt is the cartridge. It should just pull out, but I had to struggle. Inspect & change your cartridge or washers - depending on what the problem is. My tap was held to the sink with a couple of bolts and had flexible hoses, so I took the opportunity to loosen the body, clean the limescale ring/dirt under the tap body and remount the it. You may as well clean / descale the other parts too. Now just reverse the above to put the tap back together. Open and close the tap to check for leaks. If there's still a problem, check the cartridge is properly seated and the washers are all good etc.
Sep 15, 2011 | Plumbing
Water pressure has dropped off with pressurised water system
hi Peter if you have a mixer tap there are no washers there is a ceramic cartridge in the centre but that should't be the fault
the most common rectification is to undo the airrator which is the filter that the water comes out of and clean any forein matter from it
May 10, 2010 | Grohe Chiara Neu Lavatory Centerset ...
The metal ring (encasing the mixing unit housing) has popped off the unit. In an attempt to replace it, it will not stay in place. How can I make it so it stays in place?
Hi ILLOWA, Happy Newy Year! I believe the metal ring you are referring to is your mixer’s “Planetary Drip Ring”. The drip ring is a compression/friction fitted piece that should stay on during normal use. It should be on tightly enough that to remove it by gently tapping the edge of the ring with a straight screwdriver at several places around the ring.
If the drip ring is falling on its own, than you might try the reverse on trying to remove the ring and tap the bottom of the drip ring gently with a few taps of a soft faced mallet or hammer (use a piece of wood between the hammer face and the ring to protect the ring) around the ring to see it that seats it any better.
The ring may only fit tightly on the mixer in one orientation. Mark the outside of the ring with a small piece of tape so you can keep track of the orientations you have tried. As you attempt to seat the drip ring, if it will not stay on, then rotate the drip ring clockwise, just a bit, and repeat the process. Ideally you should find one position where the drip ring will fit securely and stay in place. Give the drip ring one final squeeze for good measure. Keep an eye on the drip ring the first few times you use the mixer to make sure it is not working loose again.
If it still comes off, then the ring opening has been expanded to the point that it won’t ‘grip’ the mixer head where it’s attached. You can either attempt to ‘crimp’ it with a pair of pliers at a few points around the ring so that it may grip better, or you may want to order a replacement drip ring for your mixer for which you’ll need the Parts List manual. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM90P, and select the file KSM90PSWH0.pdf (354.08 KB) listed under Parts List (16) (check to see that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. Nos. 26, Planetary Drip Ring, which is the part you want to order.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Also, while your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, repair, and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! – hslincoln
Jan 08, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Change tap washer
hi first turn of your water to the tap open the taps to empty water your mixer tap con now be pushed down and twisted to come out
Nov 10, 2009 | Home
Have a grohe euro plus,turn off shower and it drips.is it seals or pressure balancing cartridge?
if its a inwall mixer tap, you will have acartridge, ,depending on how old mixer is, I have found most of the time only the O-rings at the base cartridge wear out, by replacing these usally stops the drip. IF you cant find the right size o rings , you can purchase another replacement cartridge from most major plumbing stores
Nov 06, 2009 | Plumbing
I am looking for a replacement cartridge for a Roca Pasific bath mixer tap
Try The Faucet Parts store out of Arlington, TX. They specialize in faucet replacement parts. Their number is 817-649-8919. I bet they would be more than happy to ship you what you need.
Mar 04, 2009 | Roca Pacific Semi-Recessed Basin - Black
Plumbing Logo
171 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
