Question about Canon PIXMA MP130 All-In-One InkJet Printer
Paper jammed I see the small bits of paper in the printer (PIXMA MP130) but cannot finmd a way to get them out so other paper can move through. Can you help?
  • 71 Answers
Hello Dear,
Use a vacuum cleaner or you should take your printer to the service center and get it serviced.
Warm Regards,
Manoj Joseph
+91 9352008418
Posted on Jun 17, 2008
How to remove paper jam in Canon MP130 Series printer
Examine the paper output tray and the Auto sheet Feeder and then gently remove the jammed papers out.
Press O.K.
Lift the scanner unit open,firmly grasp the jammed paper and gently pull it out.
Close the scanner unit.
Turn the printer off and on.
Now try printing.
Hope this helps.Thanks!
Please rate this answer.
Oct 26, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Getting paper jam error, but no paper jam that I can find
Hello, there is on problem please off the power of printer around 3-4 minute. And reinstall your printer software in your computer and it will work best of luck for this process.
Nov 07, 2010 | Canon PIXMA MP130 All-In-One InkJet...
The paper keeps getting stuck. It feeds in from the left only and get jammed
Most likely there is a small piece of ripped paper in the paper path, making the paper stop at one side. Use a flashlight and look for it.
Always make sure the whole paper comes out when it gets stuck.
Oct 16, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Mp130 cartrage jammed. computer message says that the paper is jammed. but their is no paper jammed.
The message on the computer is rather generic.. you will get a paper jam message for many different problems. the series of flashing lights on the printer is a more accurate way to tell what is going on. go to the troubleshooting section of the Canon website to get an accurate idea. Most likely it has a broken paper pickup shaft.
Sep 30, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I am getting a paper jam error message, but there is no paper jammed in the printer
It could be something else blocking the sensor. You have to inspect it real close. It could be very small. or a wire has come off the sensor.
Sep 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Lcd reads "check printer 5000"
Usually means you have a paper jam. Turn the printer off. Check inside for any bits of paper, remove the printhead. Put the printhead back in and restart the printer
Jan 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Cannon pixma mp130 5100 service error
Hi You can Try 2 things.
Hope you try it may work
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 31, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Catridge jammed
check to make sure there is nothing obstructing the carriage and the paper feed area, sometimes things can get in there mysteriously :) I have found all kinds of things, there could also be a small bit of paper jammed up in there keeping things from operating smoothly.
Mar 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Printer gives an error.
maybe the paper needs to be riffled(run your fingers through it before placing it in the tray)..make certain that your paper is not offset in tray, as well..
new printer drivers needed? click here
Mar 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
I have a jammed cartridge, what can I do
The last two MFP printers brought into my shop had problems from their original setup and opening. Check the inside, anywhere that the paper path or cartridge line touches, make sure there are no small shards of plastic or remaining packing materials like tape or cardboard flakes deep in the printer. There are also small jam sensors that protrude very little from the paper path that if knocked over a little bit can become loose and ironically cause jams.
Oct 23, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
old marine
old marine
