Question about HP Pavilion 735n PC Desktop
Need to remove front cover to replace cd rom drive on hp 735n computer. How is it done?
  • HP Master
  • 7,733 Answers
In some models you need to take screws. But most of them are easy just play around with the frond cover, that is just set with rubber pins onto the cahsis, so unplug them and also the side panel of the case.You wil find screws taht hold the CD_ROM.
Posted on Oct 06, 2010
Testimonial: "Like you said, play around with it and you will find the latches. Got it off in about 15 minutes. Thank you"
How to open the disk drive
Open the Computer folder in Start Menu, select the DVD Rom Icon, right click, select Eject. If a DVD or CD has exploded inside remove DVD Rom and open the DVD case. Sometimes if you open the front case door cover and access the DVD/CD drive door you will see a tiny hole to insert a open paper clip that will open the tray.
Mar 19, 2013 | HP Black Compaq Elite 8300 All-in-One...
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | Computers & Internet
I have a hp pavilion a562n computer and im looking to replace my dvd drive. Can you give me a detailed guide on how to do this???
Go to this link
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=408385&
Its to the manuals of that computer. Select PART REPLACEMENT INSTRUCTIONS. Download the file. The file is a pdf file that shows you how to remove it and install it.
hope that helps
Oct 26, 2010 | HP Computers & Internet
CD in stuck in the computer and I can't get it out using the eject button. How do I get it to come out?
hi,
its too simple. you dont need to worry.. Check the front side of the CD ROM. you will find there one small hole. Now just take a thing, which is around the 4 to 6 inch (min is 4") long and can pass through that hole (for eg. take medium size U pin, and remove all bends and make it straight or long needle) Now insert this equipment in that hole and press. your ROM will eject...
Hope this has helped you ... Thanks....
Jul 19, 2010 | Computers & Internet
Bad DVD/CD Drive
ok to be clear you want to change the dvd cd rom drive corrct? here how to first thing first take of both sides of the computer (im telling how to for 99'9% of comuters not specifcly yours) there will be 2 screws on each side of the drive take these out now 2 ways to remove from here it will 1 slide out the front or 2 it will be stuck from the from becouse the farsade is holding it in (remember to take both cables out the back of the dvd rom drive) if its 2 then then there will be 2 ways to go from here if there is a lot of space at the back then take it out there if the box with wires is in the way there are 4 screws holing it on take these out and move but dont take all the wires out of everywhere the box of wires (psu) then take out old dvd rom drive and replace it put the psu back in and screw it in then screw in the dvd rom and wire it back up your done turn on the computer it will go to windows and install new device if howver there is not a lot of room and removing the psu wont help then you need to remove the farsade at the from (front cover) ther eis normaly 6 clips at the side push these to remove the farsade and pull ou the dvd rom and replace it that way hope this helps i can provide further info if needed just ask
Mar 17, 2010 | Gateway DX482201 (PTGA002002) PC Desktop
Replace the disc drive on hp pavilion notebook
1. First of all, you need to shut off your computer . To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
5. Now before touching anything inside, it is a good idea to hook up to an anti-static wrist strap. If you dont have an anti-static wrist strap, just touch the side of the computer where it is metal to deshock yourself. Then when you touch the inner components you wont risk damaging any of them.
7. Find the CD-Rom drive, it should be about 1.5 inch thick 5 inches wide, and 6 inches long. Unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
8. Once you find the CD-Rom drive, find the screws holding it onto the chassis. unscrew those screws on both sides of the Cd-rom drive. Be careful not to unscrew any screws holding the cd-rom drive together.
9. Now, you just have to remove the cd-rom drive, carefully by sliding it either forward or backward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
10. Now that you've removed the cd-rom drive the next step is to install your new CD-rom drive. To do this, simply slide the cd-rom drive in from the front of the computer, controls facing forward. Plug all the plugs back into the cd-rom and screw everything back into place.
Jan 17, 2010 | HP Pavilion TX2000Z Notebook
I would like to replace one CD drive from me Dell Dimension 2400 System service tag DXY0631. I can't find the screws that will allow me to remove the section that holds the 2 CD drives in the chassis so I...
Hello there:
on some of these dell's like mine i need to remove the front cover to acess 2 screws that hold the whole assembly onto the chasis then it will come out and there are 2 screws on the opposite side of the drive that is holding in the cd rom and in my other dell i ned to remove the front panel and there is a tab that i need to press and thedrive slides out the front of the computer so please try both oif these and see what helps you out ok?
best regards michael
Oct 04, 2009 | Dell Computers & Internet
How to replace CD-ROM in Medion MD40566
Generally what you will need to do is first open the computer case. Then you will see 2 screws on each side of the CD-Rom Drive. You will need to remove these screws. Now you should be able to slide the CD-ROM forward away from the front of the case. Before you completely remove it you will need to remove the cables at the back of the CD-ROM before removing them note the position of them. Now that the CD-ROM is removed bring it to the store and ask the associate for the correct replacement. Once you bring the replacement home installation is reverse of the listed procedure. One thing to not is the position of the Jumper on Slave, Master, or Cable Select. This will be explained on the instructions that come with the new drive. Whatever the jumper setting is on the old drive make sure it is set the same on the new drive. Once this is done turn the computer on and you should be all set. Good luck and keep me posted.
Thanks - Tech101
Jun 24, 2008 | Medion Computers & Internet
Removing cd rom
Preparation Steps before removing CDROM:
1.Power down and remove power to the system.
2.Remove access panel.
3.Remove CPU fans and fan basket.
4.Pull the system tray out until it stops.
To remove the CD-ROM drive:
1.Disconnect the power and signal cables from the CD-ROM drive.
2.Loosen the thumbscrew located in the fan basket area to release the metal locking bracket.
3.Slide the metal locking bracket away from the center of the server.
4.Push the CD-ROM drive out of the front of the chassis from the interior of the system.
5.Pull the CD-ROM out and away from the chassis.
Apr 12, 2008 | HP Compaq ProLiant ML530 Server
HP Pavilion 735n PC Desktop Logo
166 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
