Question about Toshiba W522 VHS VCR
Should I turn OFF thew recorder after I set it to time record??
  • Toshiba Master
  • 8,457 Answers
No,u can't turn off power the VCR.Than there no power to the VCR,it not on,only on standby power.
Posted on Oct 06, 2010
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
Tip
Schedule the recording while record streaming music from internet
Tips on schedule the recording while record streaming music from internet
Then found a tool named streaming audio recorder. It can schedule you recording as below.
1. set the "Starting time"
2. Set the "Duration" time.
3. After recording, help you turn off the computer.
i am not sure this can help you .
it supports all popular streaming media protocols, HTTP, RTSP, MMS, MMSU, MMST, etc.
on Dec 29, 2008 | Apple Streaming Networks PMR-100 iRecord...
How to record
Be sure you have first set the clock correctly. After setting timer recorder time, channel, speed etc. hit enter to highlight the setting to be sure you have it. Press setup to put you back to tv screen. Then press t-Set button on remote. Unit will automatically shut off and there will be an amber symbol on the unit lcd along with the time. This indicated the unit is in the timer mode. It will automatically turn on and record the program at the set time.
Sep 26, 2012 | Sylvania DVR90VE DVD Recorder/VCR
How do I change my recording on thew vtech 6.0
Since you neglected to specify the model of your VTech 5.8GHz system I can only suggest you enter it into the search box here to download a copy of the manual.
Aug 30, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
I would like to record a show/shows on tv using my lg gc990w 6 head hifi stereo vcr . A work colleage has told me I cant do this because I am trying to record a high definition channel. Is this true or...
you can try setting your tv to record and your vcr to record at same time,,,i have digital tv and set record time,,then on vcr set to record avi at same time,,the only problem is the tv turns itself on when timer starts,, hope this helps and makes sense,,cheers.
Feb 08, 2011 | LG Televison & Video
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Dvd player/recorder DRW 500 does not pick up channels after installing DTV converter box. it will record directly but can't be set for timed recording because it did not find channels
You want to set the recorder timer to record the out put channel of the converter box (either 3 or 4 ) then tune your converter box to the channel you want to record, and leave the converter box turned on until you are done with the timed recording.
Jun 30, 2008 | Televison & Video
Vcr Samsumg Vr8460
1. Is the VCR coming on in the timed mode and recording? Make an experiment- set up a timed record for just a few minutes in advance. Have a tape in the machine- then wait a few minutes & see if it indeed comes on and records. This should for sure help you diagnose your problem.
Note: When a timed record is set up, some VCRs must be turned off, or a particular button pushed to activate the timed record mode, where it will wait for the specified time and come on by itself..
2. Video source set correctly? If all you get is a blue screen, or a moment of snow, then the timed recording is happening, but there is no signal present.
Jun 17, 2008 | Televison & Video
Set a timed recording
Do you have your operation manual? It will tell you how to set up a timed recording. Recording options are set via the remote. Look for an option as "Scheduled recording" or similiar. Date, start & end time, channel, recording speed are all set. If you are missing your manual do a google search with your model number. A quick look at the Samsung website was not fruitful.
Jun 02, 2007 | Samsung VR3607 VHS VCR
Toshiba W522 VHS VCR Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
