Question about Dell Inspiron 531s Desktop Computer
Inspiron 531s will not boot up, keeps beeping, saying it is in power save mode. How do I fix the problem
  • joecoolvette
    joecoolvette Oct 06, 2010
    The beeps you hear are BIOS Beep Code beeps. The computer's way of telling you something is wrong, and an area to look into for the problem. The BIOS Beep Code is just that. A code. For example: One Long beep, two Short beeps, then a pause, (Period of silence), then the beep code starts all over. What series of beeps do you hear? One thing you might do is to clean the contact pins on the bottom of your Ram Memory module/s. (Stick) The gold plated contact pins can develop corrosion after time. Computer unplugged from power, observe Anti-Static Precautions. Remove the Ram Memory module/s, and use a pencil eraser to clean the contact pins. Use air from a can of compressed air for computers, or from your mouth, and remove the eraser dust. Reinstall the Ram Memory module/s. (Monitor is in Power Saver Mode, because there is No Video Signal coming from the computer. No Signal. This is because the computer isn't working)
  • Dell Master
  • 998 Answers
System Beep Codes The Inspiron™ 531 / 531s system can emit a series of beeps during start-up if the display cannot show errors or problems. These series of beeps, called beep codes, identify various problems. One possible beep code consists of repetitive three short beeps. This beep code indicates the computer encountered a possible system board failure.
The series of beeps has a 3-second delay before it repeats. The series and delays continually loop until you press the power button.
Code Description Suggested Remedy 1 BIOS ROM checksum in progress or failure System board failure; covers BIOS corruption or ROM error 2 No memory modules detected
  1. If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  2. If available, install a good memory module of the same type into the computer.
  3. If the problem persists, contact Dell.
3 Chipset error (North and Southbridge chipset, DMA/IMR/Timer Error for Intel® platform); chipset error System board failure. Power LED is blinking amber. Time-Of-Day Clock test failure Gate A20 failure Super I/O chip failure Keyboard controller test failure 4 RAM read/write failure
  1. Ensure no special memory module/memory connector placement requirements exist.
  2. Verify the memory modules you are installing are compatible with the computer.
5 Real time clock failure. Possible battery failure or system board failure.
  1. Replace the battery.
  2. If the problem persists, contact Dell.
6 Video BIOS test failure Video card failure 7 CPU cache test failure Processor failure
Posted on Oct 07, 2010
Dell inspiron 5315 when trying to boot up it say power save how to fix
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
Jun 15, 2012 | Dell Inspiron 531s Desktop Computer
I have vista on my dell inspiron 531s. Once it goes into hibernation, it won't come out of it when I move the mouse. I have to turn it off without powering down correctly. How do I fix this?
If it didn't used to be a problem, but now is, and you've added some program recently, try removing that program. Other than that, the solution is probably too difficult to track down, so open the power settings in your control panel and set the power savings mode to never, never, never to keep it from hibernating.
May 06, 2011 | Dell Inspiron 531s Desktop Computer
My dell isporion 531s will not boot past the opeing logo,, only 2 options are f2 set up and bois screen need some help
You may want to do a system recovery. Dell computers allow you to do recovery by pressing "Ctrl and F11" upon boot up.
Jul 24, 2010 | Dell Inspiron 531s Desktop Computer
My dell inspiron 5315 keeps entering power saving mode
Go into control panel and look for Power options icon. CLick it and change your power options to "always on" or performance mode...its one of those options.
Jun 09, 2010 | Dell Inspiron 531s Desktop Computer
Computer is making a clicking, and beeping noise
sounds like hard drive failure , but may be settings in cmos
Apr 22, 2010 | Dell Inspiron 531s Desktop Computer
My dell inspiron 531 desktop enters auto detect power save mode
start your computer in safemode and then turn off all power saving features
Apr 10, 2010 | Dell Inspiron 531s Desktop Computer
It keeps saying configuring updates 3 of 3 0% complete then says shutting down
For some reason it did not install the updates correctly.. can you boot into safe mode? or last known good config?
Feb 26, 2010 | Dell Inspiron 531s Desktop Computer
Ggg
Try to boot your system in safe mode ( Restart and keep taaping f8 )
Try clean boot
Try to repiar the operating system
Jan 23, 2010 | Dell Inspiron 531s Desktop Computer
Inpirion 531s no boot no beep
It could be a faulty power supply try replacing that with another one ,if that doesn't work it's very lokely the motherboard is kaputt!..Good luck John
Aug 04, 2009 | Dell Inspiron 531s Desktop Computer
Dell Inspiron 531s Desktop Computer   Logo
1,595 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
