Question about GE Profile Performance 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25PPBWW
I have a GE Profile Performance 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25PPBWW that keeps getting stuck in the off (and occasionally on) position. When I find it stuck in the off position, I turn the freezer thermostat dial all the way to zero and the fridge will usually kick right on (Other times I hear something begin to "turn" (like an egg timer) behind the thermostat knobs, but the fridge eventually begins to cool). The problem started a few months ago, but I just kept turning the knob to make it start cooling again. It actually worked normally for awhile, but the problem has now returned worse then before (I am finding the fridge stuck in the off position more now).
  • 3 more comments
  • ryanmcorder Oct 06, 2010
    Do you mean part number 425 at this link:http://www.appliancepartspros.com/partse...
  • ryanmcorder Oct 07, 2010
    Do you mean the plastic knob I turn? Because when I pull it off it does not seem to be broken. Thanks for your help by the way!
    I had a feeling that might be the case, and had actually been to the site you posted. Is this fairly easy to replace, and about how long do you think it will take? Thank you for your help!
  • ryanmcorder Oct 12, 2010
    I received the part today and tried to install it, but got confused during the installation and cut what I think is the capillary wire because I thought I could just splice the old and new capillary together. Would this cause the fridge not to turn on? Thanks for your help.
  • ryanmcorder Oct 18, 2010
    Great help! Thank you.
  • GE Master
  • 1,711 Answers
Your problem is very easy to understand and very frequent. All you need is a new thermostat. The knob you keep turn on and off is acting like an electrical switch with contacts which is now stuck either in off or on position.
We have here below for you a part layout of your fridge where you can see the thermostat which is part 424 ,
Control temp
Part Number: AP3156221 made by GE
And the link is
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=228779&diagram_id=20846127#d20846127
At this link you see the code the price and even if you like to order it online.
Posted on Oct 07, 2010
  • espressonist
    espressonist Oct 07, 2010
    The operation is very easy operation.
    Before you start remove fridge from electric power.
    First you need to remove knob white wheel. Under this you will find two Philip screws which secure the thermostat. You may remove the plastic bracket cover and here is the thermostat with to wires on the end. Remove the two wires, don't worry about polarity they can be in any place.
    Now you need to pull out the capillary wire and try to remember how it placed so you do the same with new one (you can take a photo if you prefer) that's it.
    Follow the opposite order to install the new thermostat.
    For a professional this a piece of cake job 5 minutes, but we advise you to take your time so to avoid the possibility of destroy any other part in the process.
  • espressonist
    espressonist Oct 13, 2010
    Unfortunately you have damage the thermostat. The capillary and body of the mechanical thermostat are factory assemble together in a special way since the capillary work in a very special and sensitive way to transfer the sensed temperature to the body.
    Now they cannot put together by any way and of course you need a new thermostat
    Genius:
  • 1,478 Answers
I think the thermostat knob is bad and will need to replaced, i will advice you replace the thermostat knob on your refrigerator to fix the problem.
Take care.
Posted on Oct 06, 2010
  • Jimoh Adeleke Muyideen Oct 06, 2010
    Am referring to the freezer thermostat dial you normally turn.
Ice dispenser not working
you might need to change filters. if you have hard water you might have to replace intire water line.
Sep 27, 2012 | GE Profile Performance 25.2 cu. ft....
GE Profile Performance dryer drum is clunking and making a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | GE Profile Performance 25.2 cu. ft....
Food freezes in refrigerator
Ge side by side Fridges are gaining bad press for their bad thermostats. they simply just dont last in moist environments, and this is what you will need to replace.
In your case it will be called the Temperature sensor.
Mar 13, 2010 | GE Profile Performance 25.2 cu. ft....
No water to ice maker
check water in dispenser is no water check main supply and water filter
Feb 07, 2010 | GE Profile Performance 25.2 cu. ft....
Ice dispenser has rust
The rust will conterminate your ice, please have the spiral ice dispenser replaced.
Jul 30, 2009 | GE Profile Performance 25.2 cu. ft....
Ge Profile Refrigerator
take your kickplate off and adjust the screws on either side shoulkd help
Mar 19, 2009 | GE Profile Performance 25.2 cu. ft....
My ice maker make ice slow sometimes and also my water despensor has quit working. Does the tfx 25 pr have a water filter somewhere
i think so try looking in the top rear of the ref. or below the doors in/behind the grille this is wher they usually hide them
Jan 10, 2009 | GE Profile Performance 25.2 cu. ft....
Refrigerators Logo
300 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
