Question about Nokia E52 Smartphone
My e52 is not recognized by pc suite when connected via cable. how can i fix that. thx
  • 10,421 Answers
How am i going to back up my E52 messages,I have Nokia E52 how to back up messages, contacts, tones, images and videos. thanks
Use nokia pc suit. Connect the phone via usb cable and select nokia pc suit on phone. Then backup using ur doftware
Apr 07, 2014 | Nokia E52 Smartphone
How can i format my phone, nokia e52
*#7370# is the format code.If you don't know the security code, try to generate the code from this trick
1. Downoad [ANT] Simple Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel as shown below
7. Now click on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window.
Thanks For visiting Fixya
Aug 18, 2011 | Nokia E52 Smartphone
How will I know if the software i'm using is already updated?? The model is Nokia E52-1. Thank you very much
Connect your phone via PC Suite. There is a button in PC Suite with Down Arrow Icon and if you put your cursor there you'll see "Update Phone Software". Click this icon and it will give you notification weather your software update or not. You must connect the internet to do this.
The phone usually have application to update software, see in your Application folder.
Hope this help and RATE if helpful please.
Feb 01, 2011 | Nokia E52 Smartphone
How can i format my phone memory
You can't format phone memory You can forma(flash) the entire phone(actually formatting means deleting the entire system file it's also called as flashing).
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE**
**Please don't disconnect while updation process
Thank you
Don't forget to rate
Jan 17, 2011 | Nokia E52 Smartphone
My laptop does not recognize my n97 when connected via usb
Have had many similar issue with Nokia phones & PC Suite connections - works fine then stops - in add remove programs there is an entry called PC Connectivty Solution - it does not say Nokia unless you go change then it says Nokia - remove this, the Nokia suite & Nokia Connectivity Cable Driver - restart PC, switch off phone, remove battery, switch on, reinstall and it should work.
Good luck.
Oct 14, 2009 | Nokia N97 Cell Phone
We have imp. data in mobile how to backup it first and then we can think for format
Use nokia PC suite to backup data. The software can be downloaded from nokia.com
Once PC Suite is downloaded and installed, connect your phone via the cable provided. It will take a few minutes for the PC to recognize the device and install relevant drivers. Once it installs the drivers (follow on screen instructions), you can use the backup option to backup data.
Make sure you choose PC Suite Mode when you connect the cable with your PC.
Sep 16, 2009 | Nokia E51 Smartphone
Tweak nokia e65
replace your pc suite with the new Nokia OVI
it has far less problems and issues like compatibility problems
after you've installed it and all its features and restarted your pc:
unplug mobile from pc
open something called "Get Connected Wizard"
select "next"
select "cable connection" > "next"
now you should plug your device and if it asks you->choose nokia pc suite
the program should recognize your device then..
enjoy.....
Sep 12, 2009 | Nokia e65 Cellular Phone
MOTOROLA RAZR V3M MP3 DRIVER/UTILITY DOWNLOAD
HI,
I BOUGTH A DATA CABLE FOR MOTOROLA RAZR V3M OVER EBAY BUT THE DRIVER/UTILITY CD WAS NOT INCLUDED, NOW I'M TRYING TO DOWNLOAD SOME STUFF INTO MY RAZR AND PC WILL NOT RECOGNIZE IT. WHERE CAN I FIND THE DRIVER TO DOWNLOAD OVER THE WEB?
XP box won't see the phone when connected via the USB cable. The phone charges when connected. Have swapped several times the USB port to see if connectivity was good. It was.
May 06, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Nokia E52 Smartphone Logo
274 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
