Question about Acer Aspire 5500 5570-2609 Laptop
My laptop is plugged in but will not turn on. When I try to turn it on the battery light flashes. Does the battery just need to be replaced?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Try to turn on the computer with the battery alone... Then if the adaptor alone.. Check which is the one defective.. Replace the parts according to that...If you have a different charger and a battery try with them also...
Posted on Oct 07, 2010
Testimonial: "Thank you...I tried a different charger from an older lap top that I had and then it powered up without the battery. Thanks a bunch! I work from home"
I just replaced my laptop battery - BATBL50L6. My charge light flashes orange. Win7 says plugged in, not charging. shows 0%. I tried reinstalling the ACPI battery monitor in DM.
try putting the old battery back in and see if you get the same problem. Also check where the chargers plug goes into the laptop. If it fits loosely your charger port needs replacing.
Apr 02, 2011 | Acer BATBL50L6 Laptop Battery
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
Oct 31, 2010 | HP Compaq nx5000 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
Flashing power lights green and amber will not power up
Try removeing the battery form the laptop and using just AC porwer. if it still fails you may need to replace the motherboard. :(
Sep 14, 2009 | Compaq Armada M700 Notebook
My dell laptop won't turn on and the two lights
what is the pattern that these lights flash or do they just blink repeatedly?
there is a chance that you will need to replace the system board on this laptop. continually flashing lights usually are an indication of a faulty system board or power supply. with a dell, these are on the same part.
Jul 11, 2009 | Dell Inspiron 8000 Notebook
Flashing battery light orange three times then one green?
Try charging your battery for about 30mins, light orange still came up it means your battery is faulty. To confirm, take out your battery and plug in power. If it turned on, i strongly suspected it's a battery faulty. You need to replace it.
May 17, 2009 | Dell Inspiron E1705 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
