Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
Cannon XTi My pictures turn out dark, even outside... sometimes they are ok but most of them are so dark I have to edit them and adjust the lighting and they are still too dark. Is there a setting on the camera to fix this? I have been taking pictures on other cameras for 40yrs and this is giving me grief as I paid alot for this camera.
  • 1,689 Answers
Try the camera in the full Auto mode to see if it is working correctly. Also check to see that there is no compensation set in the exposure settings for both apature and speed.
Check in the instruction manual to see how to get in to these settings from the user menus.
If this does not work, the camera will need to be serviced for a fault condition.
Jerry G.
Posted on Jul 08, 2008
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
adjust exposure compensation until they look correct. if you can't that means you don't have enough light, a fast enough lens, or need a better camera with more sensitivity. look at a nikon D3 it is the fastest camera there is.
Jun 07, 2009 | Canon EOS Digital Rebel XTI Digital Camera
I have a Cannon EOS Rebel XTI. And I use a white
check the white balance setting and keep the one that corrects it ...... try manual white balance if you have the knowledge
Mar 06, 2009 | Canon PowerShot S5 IS Digital Camera
Very blurry pictures on a Cannon Xti 400D
If u had took photo in very low light, pictures will appear blur. Or if you use tele zoom, u need to use tripod to stablize. In normal conditions, you can turn on image stablizer.
Feb 12, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Dark pictures using flash
You could try increasing the exposure level (press AV+/- while rotating the selector wheel to the right) but this will increase the time the shutter is open and increase the possibility of picture blur. Only other thing to do when shooting indoors is to change to a high ISO - 1600 for instance. This reduces the time the shutter is open so working together with the first suggestion you may not notice any difference!
If still too dark, you need a faster lens - you can pickup a 50mm f/1.8 lens quite cheap - this is an excellent indoor lens as the low F number means it lets in lots of light. The fixed focal length means you will have to move around to frame the shot, but they are indispensible for indoor work and a lot cheaper than a f2.8 zoom.
Feb 07, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Cannon G6 - Picture shows as portrait not landscape
Sounds like an oversensitive autorotate sensor. Recommend holding the camera very steady when taking a picture. If it still acts up, recommend just turning the sensor off, as you can use just about any photo editing software to rotate your photos if desired.
Press the Menu button, find and select the "Setup" menu, go down the list to find the "Autorotate" selection to turn it on/off.
May 26, 2008 | Canon PowerShot G6 Digital Camera
Black pictures
Check your settings - could be if very black night, and you set it to 100 iso film speed, and maybe you are on say 1/1000 of sec at maybe f16, then that's ok. You would maybe need an explosion in an oil refinery to capture much.
However, you perhaps could try this:
1 change the battery for fresh one, and see if it helps - sometimes, the shutter won't really shut if battery power is very low
2. change the mode setting to auto, and see if the flash pops up and takes a pix - then if the pix is good, the camera is still working
3. Reset the camera to the factory defaults, by:
  • Firstly press the 'menu' button, then the up button above the 'OK' as many times as needed, until you see the top folders are highlighted.
  • Press the right button near the 'OK' until you see the last folder highlighted. You will know this is highlighted when you see the first menu option that says 'Language'. The 3rd one down from that says 'Clear Settings'.
  • Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
  • Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
If that fails, back to Canon! - good luck
Apr 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Quantary Tech-10 75-300mm use with Canon Rebel XTi
Hi all
On most lenses the way to test if your old lens works on a cannon digital to set the camera to AV then set the iris to the small setting ie F16/F22 then use the stopdown button.
Things that might happen
1 The lens will close down OK
2 The error 99 will show,will need are rechip if avaliable
3 Nothing happens, will need a rechip
Q.Why will it work inside but not outside.
A. Inside the camera needs light so the iris is full open, outside the lens needs to close down and if not compatible it is unable to close down. will need a rechip
Mar 12, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 for...
Outside picture very dark even with flash / inside better
hI ,
Dec 11, 2007 | Pentax K100D Digital Camera
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
57 people viewed this question
Top Canon Photography Experts
old marine
old marine
Are you a Canon Photography Expert? Answer questions, earn points and help others
