Question about Shop Vac 952-02-62 Hang Up Pro Canister Wet/Dry Vacuum
Where to by replacement motor - Shop Vac 952-02-62 Hang Up Pro Canister Wet/Dry Vacuum
  • 171 Answers
You can buy a replacement vacuum for the same price as the motor on its own. I would recommend getting a new unit altogether as they are not very expensive to but but a fortune to fix. I have been in the vac business for 20 years and have a bit of knowledge on shop vacs and a new one is your best bet.....good luck
Posted on Oct 07, 2010
Replace a motor
You can find a replacement motor:
Replacement Oreck Vacuum Cleaner Motor , you may have a plastic housing that snaps together and may be stuck due to years of use and dirt.
800-775-6586
GoodVac com
Apr 06, 2014 | Oreck XL Ultra Bagged Upright Vacuum
System not working when switched on.Observed 3 amp fuse blown. Replaced with 13 amp fuse and switched to manual. Sparks and noise coming from one motor. ? brushes or motor need replacing.
Fuses blow for a reason. It's never a good idea to replace a fuse with a higher amp one. House fires can easily be started this way.
As for the motor, at this point the whole motor will need replaced.
Jan 15, 2011 | Beam Industries 2900 Serenity Plus Central...
I have a older m&s system central vac model av625 one motor quit the brushes are gone are parts available
You will need a new motor, not brushes, as the worn motor will tear through new brushes. Search online for the M&S motor replacement and you will see helpful sites that will provide the replacement motor. Replacing the motor is not difficult. Consider replacing both motors as the second motor will go out in the near future.
Jan 10, 2011 | M&S Systems Bagless Central Vacuum
I have a 20yr old electrolux central vac that the motor just went bad. in wondering whether to replace motor or replace whole unit i have found an electrolux unit and a aerus unit. someone told me elect....
Motor to replace or rebuild:
Depending if your motor just started to get noisy, you can take it to a private vacuum repair shop and most rebuild for around $80 to $100.00. Usually they replace top/bottom bearing and the armature carbon brushes.
If it's loud and vibrating and probably sparking. Do not bother to rebuild, the armature is now probably damaged and not worth the new parts.
Replacing the motor is pretty basic and usually saves you about $150.00. They're pretty simple to release out of the unit and are pretty simple to remove and reinstall.
To find out your replacement motor number you will need to find the stamped model number on the motor itselt. It is a 6-8 digit number. That is the Ametek Motor Model number. Ametek is used in pretty well all central vacuum systems. Motors range from $99 to $239.00
www.ametekfsm.com/Product_Compare.aspx?MT=1&MST=1&FanStyle=Bypass&Discharge=Tangential
Dec 30, 2010 | Electrolux Centralux Vacuum
Motor to my electrolux centralvacuum has burned out .Is it a good idea to just replace motor?
Replacing the motor yourself voids the warranty on the motor (1 year). You can take it to an authorized Electrolux (now Aerus) service center and let them replace generally for only the cost of the motor.
Replacing the entire unit will give you a 5 year warranty on the unit, including motor and fan assembly.
I don't know how old your unit is, but if more than 20 years you might consider replacing it due to updates in the other components and potential of them becoming obsolete.
Aug 26, 2010 | Electrolux Central Vacuum
How do you get to the motor for the ridgid wet dry vac model #WD 12450
the manufacture does not replace the brushes...depending hon how old it is you might be able to get the powerhead replaced. The motor is made in China. I heard of some guy cross refrencing the motor brushes at ACE hardware if you can believe it
Sep 14, 2009 | Vacuums
Sparks from motor when turned on
there's a short circuit on the motor armature.. needs replacement but it can be repaired depending on the problem.
Apr 15, 2008 | Vacuums
Power head
If you have checked the power delivery down to the powerhead and you have current running to the powerhead, then you likely have a burned fuse. There is a fuse built into the powerhead motor and is usually located on the field winding. This is not easy for a novice to replace and even most professional repair shops will replace the motor. It is possible to replace the fuse if you know what you're doing, but if the fuse blew, there may be a more serious problem, after all, the fuse is there if the motor starts to experience distress and the fuse will blow to avoid any electrical issues. The fuse can blow if something is jammed into the roller and causes the motor to labor heavily. If this is the case, then the fuse can be replaced safely. If the motor is burning out, then a new fuse will just blow immediately after replacement. What I do is take the fuse out and run the motor without it to see if the motor is still viable and replace the fuse if the motor proves to be o.k.
Feb 08, 2008 | Eureka 6831A Bagged Canister Vacuum
Looking for Replacement Motor for Bosch Ultra 1450W Canister Vacuum
If you are finding BB's. then the bearings are bad. You could pull the motor and take it to a place that rebuilds motors to see about replacing the bearings. If it is a Lamb or amtec motor, there is a number stamped on it, you can match up another motor with that number. Go to a place that sells Vacuum repair parts and they maybe able to get you a new motor.
Dec 24, 2007 | Vacuums
Shop Vac 952-02-62 Hang Up Pro Canister Wet/Dry Vacuum Logo
273 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
