Question about TurboChef TORNADO Electric Oven
I have a tornado elec oven when you turn it on the screen just says please wait warming up
    New Friend:
    Problem Solver:
  • 6 Answers
What does the CC temp and IR temp read after 15 min of warming?
Posted on Oct 26, 2010
Turbochef tornado toaster wont get to menu, just warming up
The most common issue with this is a bad IR element. When the oven is cold remove the metal rack. you will see the IR element on the bottom. turn the oven on. wait 1 min. open the door and see if the bottom element is warm at all. If the bottom element is still cold then you have a bad element.
Feb 13, 2013 | TurboChef TORNADO Electric Oven
Hello, I have a Turbochef tornado oven, while operation i am getting a Fault code Close door error and it keeps on coming while closing the door with a beep . Can anyone please try to resolve the error...
seems like your primary switch isn't closed correctly or it might bad.
step to trouble shoot
OVEN HAS 5000 VOLTS MOVING INTO IT PLEASE BE CAREFULL
1.press back key to turn off the oven.
2.Open left side pannel.
3.press 'back' and 'enter' key together.Then, enter 9428 and then press enter.
4.You will be directing to an testing screen.At the bottom of thetesting screen there are many alphabets.In which you can see 'P' ,'S' and 'M' .
5.Open the door and watch what happened to alphabet 'P'.I meant to say that when door open alphabet will highlited ,and when closed its seems an regular 'P'
6.open door and close the door .And also keep an eye on the primary switch at the top left corner of the oven where the door latches engaged.If it engaged very nicely and you still see an highlited 'P' in the testing screen then REPLACE THE PRIMARY SWITCH OR IF SWITCH IS OKAY THEN CHEK THE WIRING UPTO MAIN BOARD.
7.If switch doesn't latches properly then adjust switch ,by lossning the screw and aligned it properly.
PLEASE LET ME KNOW IF YOU KNOW HOW TO USE MULTIMETER,SO I CAN EXPLAIN YOU HOW TO CHECK THE SWITCH.
ALSO PLEASE RATE MY ANSWER.
THANKS
May 12, 2011 | TurboChef TORNADO Electric Oven
The oven not holing the hit
does it reaching to optimum temperature or its not getting the ready screen.
It under warming situation.
then it might be IR element or convection heater.
let me know if you know how to use volt meter.
then I can explain you in detail how to troubleshoot
thanks
please rate my work
Apr 01, 2011 | TurboChef TORNADO Electric Oven
My turbochef oven display wont turn on. i just replace the solid state relay
HI,
you said it won't turn on.Is that mean its not warming up or its totally off.
please reply me with questions.
I will be happy to assist you.
thanks
Mar 15, 2011 | TurboChef TORNADO Electric Oven
Problems with TurboChef TORNADO Electric Oven f8 erro.
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
Jan 21, 2010 | TurboChef TORNADO Electric Oven
TurboChef Tornado Door Open?!
check the door switch... also you can try a hard reset ( unplug power) ( if hardwired in you will need to trip the breaker) hope it helps
Jul 13, 2008 | TurboChef TORNADO Electric Oven
Warming up problem
This has nothing to do with the element. This oven should only be serviced by a qualified technician. If you were one, you would already know the solution. You need to go into diagnostic mode to determine if it is the solid state relay or the cc thermocouple. After resetting the hi-limit more than once, it will also need to be replaced.
Aug 24, 2007 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
148 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
