Hi. I have a Philips Plasma TV model no. 50pf7320, and I have not been able to track down the problem which goes as this: after replacing four 58" z. diodes on the Y "Sose" board, together with 2 fuses, the screen started displaying thin vertical lines 5 inches from the bottom. What could be the source of the problem?
    Guru:
  • 416 Answers
You have a bad lower Y-DRV (or buffer, which ever you like to call it). If you want, you can change the IC itself... but they are usually smothered in hot glue. This board attaches to the Y-SUS that you were working on. It is common for the Buffers to knock out the Sustain board. I hope this was helpful, best wishes.
Posted on Oct 06, 2010
50 inch philips plasma has problems turning on. I replaced all the bad capacitors and now the green lights come on and then goes into blinking red four times. I checked all the capacitors and all of t
More specific, please ! Finally, did you replaced all bad capacitors or only replaced the power supply unit ? Because there are many other capacitors on other places that can be damaged.
Sure, the problem seems to be from one of the capacitors, but you have to know how to find the damaged one (and with the proper instrument will be more easy). Howewer, to buy a good instrument is more expensive than to service your TV set (my opinion). Plus guaranty.
Sep 11, 2017 | Televison & Video
My phillips tv 50 plasma hd can't show picture
Problem is in either power supply or - my bet - the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
hope that help out......
Jan 18, 2011 | Philips 50PF7320 50 in. HDTV-Ready Plasma...
Blinking red light . Tv won't turn on
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options for you. 1. Have it fixed by a professional 2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It'scalled: Fixing the Philips Turns/shuts off on its own problem. Hope this helps and Good luck.Kaufman605
Dec 11, 2010 | Panasonic TCP58S2 58 in HDTVReady Plasma...
Problems with getting channels locked in on our plasma tv
Yuo can change the pin # even if you don't know the old one then you can can turn off with the new one.
Press the 'MENU' button on the remote control.
Press cursor down to select SETTINGS.
Press cursor right twice.
Press cursor down to select MENU PREFERENCES.
Press cursor right.
Press cursor down to select CHANGE PIN.
Press cursor right once.
Enter code 0711 if you have don't know yours
Enter a new four digit PIN using number buttons. Number combinations from 0000 to 9999 are valid.
When prompted to confirm PIN, enter new PIN again.
Press the 'MENU' button to exit the menu.
Feb 22, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 50pf7320 plasma
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
DON'T FORGET TO RATE;
Sep 07, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Philips tv error code
1 long and 4 short blinks for this model is specific to class d audio amplifier on small signal board. if it is intermittent where this sometimes happens and you can unplug and replug and power back on would be related to the firmware version but if version is correct you would still need to replace ssb
Aug 17, 2008 | Philips 50PF9830A 50 in. Plasma HDTV
Four red flashes
if 4 blinks is consistent and even after unplugging tv still does not power on would recommend replacing small signal board as error is i2c communication failure which is specific to microprocessor located on small signal board
Jul 21, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips plasma 50pf7320
I have a 50 inch phillips plasma and the pixtals are taking over and color is dark the amblight is very dim,
Jun 25, 2008 | Televison & Video
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
