Question about Inverter Baldor Motor Speed Controller
My inverter(INV-0045) is flashing and the spindle does not work, What can I do? Drive,Baldor FVF1915C 10HP VMC1 7500RPM, Y?D VMC15
I have a MGE Galaxy UPS and it's giving me an intermittent alarm saying "INV. NOT. SYNC./ AC.BP".
Dear Yared,
The alarm is pretty clear about what is going on. It's a syncing issue between the inverter and your bypass supply.
What you can try is to go to the 'Command Screen' of the UPS and select Resynchronize AC BP.
Best regards,
Ron
Nov 13, 2012 | MGE UPS Galaxy 3000 UPS System
MY SCREEN TURNS BLACK AFTER YOU TURN IT ON
Hello; Most of the problems with screen going black are caused by a bad LCD Panel. The Panel and Inverter board are sold as one piece ( about $1000.00). If you want to try just the inverter board, You might get it cheap on EBAY or ShopJimmys.com. Its a fair chance that the inv board is the only problem. John
Apr 17, 2011 | Sanyo 42 in. LCD TV
Light turns on so the power works but the screen stays off
Check capacitors on the inverter boards.Replace them if bulged on top. Shine Light on screen .If image iss there then this verifys that video is present and the problem is backlight. If caps are ok look for voltage about 15v to inverters from power supply and also an inv on voltage if present replace inverter boards. If no voltages from power board ,replace power board.
Mar 23, 2011 | Televison & Video
Need installation instructions for aerosharp HR-INV-XOI-030 solar inverter
My HR-INV-X01 PV Invertor LCD Display has nothing. No power, run or fault lights however the blue safty switches note ON. What could be the problem?
Jan 07, 2011 | Solar Grid-tie Budget Package: Panels,...
Is the 612R made in USA? Is it all ball bearing?
Baldor has 26 plants in US, Canada, England, Mexico and China.The 612R is ball bearing, uses size 6203 bearings.
For more info go to www.baldor.com
Nov 01, 2010 | Baldor 612R 6 Inch Husky Grinder
I am working on a Samsung SyncMaster 170MP. When plugged in the green on/off power button light flashes continuously and the screen never comes to life. I've tested the power brick and the outputs (14V @...
It sounds like it since you have the 14v going to the inverter. Repairing inverter boards even on lcd's is 50/50 shot, so let's give it a go. If you have a dvm check the ohms on the inverter xformers ( if more than one) they should be identical in resistance. Check or replace all electrolytic caps on the board. That's about all you can do outside of replacing it, Oh, see if you have a 5v source going to in inv. bd also, check that.
Feb 21, 2009 | Samsung SyncMaster 17 in. LCD Television
Inverter Baldor  Motor Speed Controller Logo
120 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
