Question about Toro Garden
Do I need a special flywheel puller for a 2007 Tecumseh 6.5 hp engine. I need to remove flywheei to reconnecr dround wire.
  • 26 Answers
Hi Pat--
You don't always need a puller, but your chances of breaking things are greatly reduced if you do have one. If you're going to try to remove that flywheel without a puller, here's what usually gets me good results:
1) Remove cowls and panels as necessary until the flywheel is exposed.
2) Find 2 or 3 wooden stakes that will fit securely beneath the the flywheel. Square pieces about twelve inches long are best.
3) With the wood blocks underneath the flywheel, GENTLY pry up and down between the flywheel and the block evenly all the way around the wheel. You may have to tap the top of the flywheel with a rubber mallet.
Occassionally, some penetrating oil sprayed onto the flywheel's keyway will help make the separation. The real trick to doing this is to pry beneath the flywheel evenly all the way around it. Be patient and take your time. If in doubt, get any gear or wheel puller and, after tightening to GENTLE pressure, give the flywheel a few taps at its center with a rubber mallet. It should pop off.
Hope this helps.
Posted on Oct 07, 2010
Exact size of flywheel puller to remove magneto of honda wave model 2007
Hi, Anonymous I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
how to remove the flywheel with out any special tools
BikeMaster Flywheel Puller
http://www.49ccscoot.com/manuals/2001-2007_Honda_NSS250_Reflex_Service_Manual.pdf
Honda Wave Parts Manual EN pdf
http://mototh.com/files/honda/wave110i/Honda-Wave-110i-Owners-Manual-Eng.pdf
Apr 20, 2017 | Honda Motorcycles
How to change the timing chain for bmw 750 model 2007
Big job see me at www.autorepairhelp.us and will send info to you.
1131 052 - Replacing both timing chains (N62/N62TU)
1 Image ]
Special tools required:
-11 2 001 See: Toolsand Equipment/ll 2 000 Puller
-112 002 See: Toolsand Equipment/ll 2 000 Puller
-112 003 See: Toolsand Equipment/ll 2 000 Puller
-112 007 See: Toolsand Equipment/ll 2 000 Puller
1 Image ~j
Necessary preliminary tasks:
-Remove lower timing case cover See: Timing Cover/Service and Repair/Removing
and Installing Bottom Timing Case Cover (N62 / N62TU)
' Image [
Remove timing chain (1).
Remove timing chain (5).
Release screws (7).
Remove guide rails (3 and 6).
Remove tensioning rails (2 and 4).
Installation:
Maintain tension of timing chains when installing timing case cover.
Observe sparking protection on timing case cover.
Make sure timing chain (1) is correctly installed when placing it in guide rail (3).
1 Image ~j
Attach special tools 11 2 001 See: Tools and Equipment/ll 2 000 Puller and 11 2 002 See:
Tools and Equipment/ll 2 000 Puller to crankshaft.
Insert special tool 112 007 See: Tools and Equipment/ll 2 000 Puller and remove
sprocket wheel with special tool 112 003 See: Tools and Equipment/ll 2 000 Puller.
Installation:
Check sprocket wheels for wear, replace if necessary.
Heat sprocket wheel to 60 CC.
Warning!
Burning hazard! Wear gloves.
1 Image ~j
Assemble engine.
Sep 06, 2014 | 2007 BMW 750Li Sedan
Running rough and backfire
Sounds like a timing problem(flywheel key) sometimes the key will shear part way do to wear, flywheel key is located on crank end under flywheel, disassemble air housing to expose flywheel crank nut unscrew nut (impact) to see key and keyway slot in crank determine that key is not sheard and is in center of crank keyway slot. if sheared you will have to use a puller to remove flywheel from crank. install new key and reinstall flywheel with an impact gun .
Mar 05, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Trying to change the points on an old briggs and stratton 8 hp engine
Need to know what model Older engines have points "under" the flywheel. Use a wheel puller to remove after removing the nut in the center of the flywheel. Newer motors have an electronic ignition module. Follow the small wire from the magnetio. If it goes under the flywheel then you have points. If it goes to a small device on side of motor, you have electronic. You can go to http://www.briggsandstratton.com/ and look up your odel number.
Jun 23, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
No spark on tecumseh 4 hp lawnmower engine
There is a shutdown wire, this wire is grounded somewhere along the route. Look at the coil for this wire; it shorts the coil to ground so no spark can get out to the plug.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
May 28, 2010 | Sport & Outdoor - Others
How to set timing on a push mower with a tecumseh
if it is an older machine, yes, the points are underneath the flywheel---it can be removed without a puller---just a little patience will get it off
May 12, 2010 | Craftsman Push Rear Bag Lawn Mower w High...
Trouble with flywheel removal.
Yes, it's called a flywheel puller. Assuming it's a Briggs engine, it would be available from any shop that's a Briggs and Stratton dealer. If you want the part #, let me know and I'll get it for you. I'm not in my shop now.
Jun 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know how to change the points
The engine type is key here. For example if you have a tecumseh engine you will need the instructioins for that and if you have a Kohler engine the instructions will be different.
May 01, 2009 | Garden
Garden Logo
434 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
