Question about Rockford Fosgate (P212D4) Car Subwoofer
I actually have a p3 it has a crack in it right were it says p3 how can i fix it?
  • 87 Answers
If you post in the correct section you'll get more answers.....
Posted on Oct 06, 2010
  • Chris Wilson Oct 06, 2010
    Oops, I just realized you did post it right, my mistake.
  • shaddonsimmo Oct 07, 2010
    so what can i do then?
How do i fix a leak in marble?
The photo did not come through, Is the actual marble cracked or is it the grout?
Jul 02, 2014 | Building Materials
Crack Screen
u rlly cant unless u have the parts to do it ull need to find someone who sells screens but it'all cost more to fix then it will to just buy a new ,p3 player
Dec 30, 2009 | SanDisk Sansa Clip MP3 Player
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
Workloc directory is invalid or cannot be created (server 2003 install of p3.1)
I have 2 suggestions based on my assumptions since you did not elaborate on what environment you are having your P3, network or single user.
1. If you are logging on a network before you open your P3, it is most likely that you don’t have a read and write access to the P3WIN directory or any of its subfolders. So, first you have to log into your computer as an administrator, we call it local administration, and go to windows explorer, right click the P3 directory and choose sharing and security on the pop-up. Add your Network ID or make sure your network ID has all the access enabled for these directories. Then you can go back to the network and restart P3.
2. If it is single user, check your P3.ini located on Windows directory and see if the WORKLOC directory is beyond 54 characters from the root directory. P3 was created in the 90’s when DOS was still one of the reigning OS. So it means it follows the 8+3 rule of filenaming and other limitations. Make sure that the directory listed is as near as possible to the root directory, that is from C:\ Many errors in P3 are caused by these limitations since we’re already used with the new Windows OS’s wherein you can almost create a folder with endless description. My suggestion is, in using P3, try to minimize your folder names to 8 characters, same goes with filenaming.
Jul 22, 2009 | Primavera Computers & Internet
My Primavera P6 is not letting me export it to a P3. That line is greyed out. Any other suggestions to get it exported to a P3?
You could get your administrator to give you rights to export or since that isnt likely you can bring up all of your columns copy and paste to a excel file that was created from P3. It's messy and you'll loose all your logic ties, but it's the only way I've every beaten the man.
Jul 10, 2009 | Computers & Internet
Z4MPLUS P3/P5 ERROR I found some problem in Zebra Z4m plus printer like error p3/p5.please give me solution for that
The display shows P3/P5 ERROR? You can try to load firmware, download the file from www.zebra.com press the keys - and +, turn the printer and you see FIRMWARE DOWNLOAD in screen, download the file through the parallel port.
Roberto Martinez
Jun 01, 2009 | Zebra Z4Mplus Label Printer
Left rear wheel of my Pliko P3 is broken, lower than right one
does the right side also have a spring? without being able to see it makes it real hard to guess how it works .
Mar 15, 2017 | Nautica Pliko P3 MT Standard Stroller
Motherboard processor support
no there is not much difference 3-5% not exchange your life, you can put more ram. The problem of your upgrade can be if you found the piece for make it.
Sergio
Mar 14, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Rockford Fosgate (P212D4) Car Subwoofer Logo
115 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
