Question about Kenmore HE5 Electric Dryer
Kenmore Elite HE5 - Check Lint Screen Light and error F25 Model # : 110.87081601 The power turns on and the Sensing/Revising Est Time light stays yellow. Also the Check Lint Screen light is red and stays on until another button is pushed. When I try to start a cycle, the machine just beeps, I hear a click and... nothing! I cleaned out the Lint Screen even took it apart and cleaned it from back to front and there are no obstructions. I put the machine in diagnostics mode and it showed a F25 error. I replaced the Inlet Thermistor/High Temp Thermostat as advised by the tech sheet... no go. Please help...
4 Suggested Answers
JR JR
  • 116 Answers
SOURCE: check lint screen light on and dryer not turning on
check belt might be broken,,,,
Posted on Nov 30, 2008
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore elite dryer. I just ran a load
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(((())))
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Kenmore Elite
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jul 04, 2011
My kenmore elite he3 quit working model number DADT-ELE-2406024-EL54 do you know why?
The heating coil safety switch/fuse may have been activated if it got too hot in there. It is very common for escaped lint to finally build up where it should not be. The first thing is to learn how to remove the front of the machine and inspect for a build up of lint. Happens often over time.
Nov 05, 2014 | Kenmore Dryers
Clean lint screen light keeps blinking
The clean lint screen light is just a dummy light. There is no sensor for that.
If it's giving you a AF error then disconnect the vent and run it. If it completes the cycle then it's your vent. If not it's your thermistor.
Sep 30, 2014 | Kenmore Dryers
Dryer won't run check lint screen light comes on
Did you check the obvious by turning off the 30 amp double breaker and turning it back on
Nov 30, 2013 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
I have a Kenmore Elite HE5 Electric Dryer, Model 110.8708 The dryer will not rotate when I push the start button, the "sensing revising est. time" lights up amber in the Cycle Status display...
heatman101
Jun 24, 2011 | Dryers
How to fix a code f25 for kenmore elite he5
F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch.
The f25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then reseat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
With the washer unplugged, locate the motor harness. Now unplug the motor connector to ohm the motor. Follow the list below to check the motor.
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
* Pin 4 to5 115 ohms
If the readings are close to what is listed above the motor is fine.
Live voltage checks are dangerous, and possibly deadly. Exercise caution at all times. If you are not comfortable working with live electricity I suggest you call an experienced service technician. I have provided you with a wire diagram with what the voltages should be. If the voltages are correct I would then recommend that you replace the motor control.
http://media.fotki.com/1_p,ssqftgqdqbftqgbxgtqsskgwtqkq,vi/sbbsgkqrgxstbrqrgwf/1/1303472/5961857/image5533851340308453439img-or.jpg
http://media.fotki.com/1_p,ssqftgqgtstgdfrxgtqsskgwtqkq,vi/wwkfkbqwwxkftrskdkw/1/1303472/5961857/image1769329000959650960img-or.jpg
http://media.fotki.com/1_p,ssqftgqbrdddksdxgtqsskgwtqkq,vi/stbrqrgwfxsbdkgqfbr/1/1303472/5961857/image5269611314094350944img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 09, 2009 | Kenmore Elite HE5t Washer
How to fix a code f25 kenmore elite he5 washer
F25 dispay comes on the washer stops. What is this and what can I do? Thanks, Ray
Nov 09, 2009 | Kenmore Washing Machines
I have a Kenmore Elite HE5 front loader and seem
when i clean my screen i use a cheap vacuum to **** up particles as i pull it out and vacuum screen. works so nice.. but use a cheapy that you doesnt need a bag and it will filter better as it gets clogged with lint lol.
Apr 16, 2009 | Dryers
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE5 Electric Dryer Logo
590 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
