Question about Kenmore 82822 Electric Dryer
Circuit breaker tripped, i reset it and the dryer read PF, cleared that...but now the dryer just beeps when youy hit any button like start. The dryer is a kenmore h3 gas dryer
  • 171 Answers
Try resetting the breakers again as they may have tripped again as sometimes they only move a bit and they look like they are ok but they are not.I would also unplug the dryer for thirty seconds to reset it and start again.
Posted on Oct 07, 2010
MY maytag neptune dryer center wont start when I press the start button on the bottom unit it shows PF
The PF is a power failure code and it indicates the control is not sensing any line voltage
Check the circuit breaker for the dryer is not tripped. The PF could be caused by a voltage drop during a storm but you should be able to clear it and run the dryer
Oct 14, 2016 | Maytag Dryers
I have Kenmore elite oasis electric dryer when you push start button it goes to pf code ive tryed holding down start button & it just flashes & is back to pf code how do I reset it ?
try unplugging it from power or tripping the circuit breaker(which might be easier). then re energize it and see if it resets. good luck.
Jul 29, 2016 | Kenmore Dryers
Why is there a PF code and dryer won't start?
The manufacturer has assigned this error or fault code to indicate that the appliance lost power temporarily. Press CANCEL to clear the display.
Dec 21, 2015 | Dryers
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
Displayed PF, when try to start, trips breaker.
any work done? call them back if so. Hope this is not a new dryer, if so hope it.s under warranty! Sounds like time to look for a lightly used replacement.
Mar 13, 2015 | Dryers
Whirlpool GEW9869K beeps when plugged in and lights flash
pf error is power fault most of the time. circuit board maybe! lots of things to test... but main circuit board is my guess.
Aug 31, 2012 | Whirlpool GEW9868K Electric Dryer
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
My Frigidaire dryer will not start. It shows a PF trouble code. What does this mean?
PF is showing you that there is a power problem. Check your dryer circuit breaker at the power panel. This can be a sing that one of the 2 breakers has tripped. Push the CB hard to OFF and then back to ON. Then try and start your dryer. If that does not work just respond here and I will help you.
Try selecting "No Heat" after resetting the CB and see if the dryer starts. If it does you could have a bad heating element that caused the breaker to trip to begin with. Sometimes when the heating element fails the broken link will contact the chassis and cause the CB to trip. Heating element failures are usually caused by poor airflow. You may want to look for any signs of lint in your dryer to include the lint filter area and all the way to the outside wall exhaust point.
Kelly
Oct 01, 2010 | Frigidaire Electric Dryer
The dryer works, but dont heat, and apears the PF on the display
Hi
Error PF means power failure, it appears when the dryer is unplugged or when an intermittent power failure is observed by the dryer. If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Kenmore 82822 Electric Dryer Logo
177 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
