Question about Samsung LN-S3251D 32 in. LCD HDTV
OK so i found this Samsung LN-3251D 32" HDTV LCD TV /MONITOR Last night they were throwing it out i brought it home and Plugged it in and hooked it up to see what is wrong with it i found that the Screen is all Snowy and there are green diagonal lines going through the screen how do i fix it or would it even be worth fixing
  • Samsung Master
  • 8,457 Answers
The LCD screen panel is broken or damage.Not worth fixing,sorry.The LCD screen panel are 90% of the tv.The screen panel,will cost the same as a new tv,to replaced.The tv now,only can be worth as salvage electronic boards for parts.
Posted on Oct 06, 2010
How do u connect up surround sound to my samsung tv
Connect the surround sound to cable box or use a optical wire
Jul 27, 2012 | Samsung LN-R3228W 32 in. HD-Ready LCD...
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
I have a ln-s3238d that i got a couple years ago. Last month it started getting a line of pixels running across the top of the screen. over the last month that problem has gron to four lines on top and...
Hi andrew, its not a big problem.. Decent TV. but the pixels are DEAD. that means you have to recover them by fixing the LCD. this would cost you around £40-60 for a 32 inch TV. hope this helps!
Nov 05, 2010 | Samsung LN-S3238D 32 in. LCD HDTV
46" LCD Samsung TV Model# LN-S4692D I have no picture
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
Jan 07, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN S3238DX display issues
Hi, Your LCD controler is bad. Part number...
320WTC4LV1.0 Also does it do it on the tv menu?
If not it is the Main Pcp board "logic board" part number ...BN94-01011C
Oct 27, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
I have a Samsung LCD TV - model LN-3251D. My local cable company offers HD channels over the air; however, I canot seem to get them. How do I receive these channles?
You will need a cable box with an HDMI or S-video connection from the box to the TV in order to receive actual HD signals.
Sep 06, 2008 | Samsung Televison & Video
40 in. samsung
Greetings the block,
1. Press the MENU button to display the menu.
Press the▲ or ▼ buttons to select “Input”, then press the ENTER button.
2. Press the ENTER button to select "Source List".
Press the ▲ or ▼ buttons to select signal source, then press the ENT ER button.
This should enable you to pick your current source.
I hope this helps!
Dorothy
Go Ahead. Use Us.
May 12, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
No power
your going to have to check out the main power supply or standby power supply. good Luck
Jul 25, 2006 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN-S3251D 32 in. LCD HDTV Logo
434 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
