Question about Microsoft Wireless Optical Desktop Pro Keyboard
"Assign keys" Dialog Box.
Hi, I'm having an intermittent problem in which the 'o' key activates the "assign keys" dialog box. While typing, when I hit the 'o' the dialog box pops up and halts all progress until it's been clicked off.
I've tried changing the batteries, and returning the assigned keys to default. To my knowledge, there was no change to the computer or other obvious precipitating factors (which was why I initially suspected it might be the batteries).
This is the second time it has happened. The first time it occured, it was solved by either returning assigned buttons to default or sheer coincidence.
TIA
  • 4 more comments
  • Shadoz May 30, 2008
    Thank you Worldvet, your idea seems to have fixed the problem.
    *touch wood*
  • Shadoz May 31, 2008
    Unfortunately that didn't fix the problem after all. I'm back to the dialog box popping up.
    Hi again Worldvet,
    The help would be much appreciated.
    I've owned the keyboard for approx 7 months. The problem first appeared about 1 month ago.
    There doesn't appear to be much reason for the 'onset' of the problem (no new programs installed etc).
    Since re-installing the keyboard software, the problem is becoming increasingly worse and it won't be long until I can't type the letter 'o' at all without having to click out of the dialog box each time.
    Actually, I think I've reached that point now. :(
  • Shadoz Jun 01, 2008
    Heya!
    This could be the problem. Perhaps. Maybe.
    At some point I did get a message about sticky keys but I can't remember when. I thought I had reversed the situation, but perhaps I wasn't as successful as I thought.
    Anyway, several hours ago I tried 'reversing' the situation again and so far so good! However, I'll hold off on a grand celebration for another day or so.
    I'm keeping my fingers crossed. Thanks for the suggestion Worldvet, I really appreciate it. LOTS!
    Hidden icons can now be seen. If my 'O' behaves I'll be back tomorrow to tell you (and the ratings). :-)
    I think I might have been the cat. lol.
  • Shadoz Jun 02, 2008
    Looks like the problem is sorted. Thanks for your help Worldvet. Much appreciated. :)
    Guru:
  • 859 Answers
What I would suggest is reinstalling the keyboard software from Microsoft. This is better than resettnig the defaults as it will mend any issues the keyboard software is causing, which is probably the case. When you go to Control Panel and uninstall the keyboard software. that is to say you do this once you have the CD or have downloaded the latest software version from micosoft.com/downloads You may find that when you click on the keyboard software to uninstall it in Add Remove that there is another option titled Repair, if so, choose that and let the OS repair the installation.
Kind Regards,
Worldvet
Posted on May 28, 2008
  • 3 more comments
  • Glenn Rogers
    Glenn Rogers May 31, 2008
    Can I work with your some more to get to the root cause of your problem? Much of trouibleshooting is a process of elimination.
    How long have your owned this keyboard?
    Worldvet
  • Glenn Rogers
    I can appreciate your frustration as I've been doing this for a very very long time and sometimes these keyboards just malfunction, usually this can be resolved in software. The keyboard does have a circuit board inside.
    The thing to do if you have one is to use an alternative keyboard while I give you a walkthrough to clean up your system registry from this software.
    Just to remind me, and I don't mean to patronize or pander to you, but you have turned the keyboard over and tapped it on your desk to shake out any stuff that has gotten into the keyboard or unstick any stuck keys.
    Lastly, before you do anything above you need to check and see if you have somehow enabled Sticky Keys. Sticky Keys are accessed via the control panel keyboard, handicap features. What Sticky Keys does is keep the Alt, Ctrl and Shift key enabled after typing it for nearly five seconds while users with no digits on their hands or no hands and using a pointer can type.
    To check this go to Control Panel, Accessibility Options, the first property sheet you see has a check box to enable disable Sticky Keys. Your Control Panel may be different but you hunt for what sounds like Accessibility Options, which used to be called Handicapped Features, (that was considered too perjorative), and your version of Windows may be slightly different but these property sheets that get you go enable/disable Sticky Keys can be found.
    If you get lost somewhere let me know and if Sticky Keys are enabled let me know as I will remember to suggest this earlier with the next person. Usually, reinstalling the software resets the defaults but your version of Windows may have kept things that were enabled, enabled. That's software for you.
    Looking forward to hearing back,
    Worldvet
    Do you know what Sticky Keys are or have you check that?
  • Glenn Rogers
    Glenn Rogers Jun 01, 2008
    That's great, but beware that you can enable Sticky Keys inadvertently by holding the Control key down for five seconds.
    Sorry it took so long for me to have this dawn on me, thinking reinstalling the software would reset this option.
    There is actually a unique icon in the System Tray that indicates when sticky keys is on. However, if "Hide Inactive Icons" is active it probably won't show. You can change this by right clicking a blank area of the task bar and choosing properties. From there deselect the check box for hide inactive icons.
    If this does remain fixed after a day, would you be so kind as to change the rating for my solution to fixed. It would mean a lot. I don't mind spending a lot of time with someone. I'm doing that now with someone's laptop that has a difficult problem. Those of us who work in the free area and not just the pay area appreciate the higher ranking when a long series of messaging finally fixes a problem.
    Its greatly appreciated and I too will keep my fingers crossed for you.
    Meanwhile, turn off hide inactive icons so you can see if your cat? has walked on your keyboard and done this. This, believe it or not, is rather common If you need more help of doing this task let me know and we'll get through it.
    Regards,
    Worldvet
  • Glenn Rogers
    You wouldn't believe how many cats have caused people trouble with their computers by walking on the keyboard.
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 02, 2008
    You are very welcome and remember we all want to see your problems solved and only a very few will give up on you if the first couple of things don't work.
    I was glad to stick with you until, the answer came to pass... it usually does.
    Kind Regards,
    Worldvet
Have a locked of microsoft office 2007
Maybe you have a free trial version of Office 2007 and the trial period has ended. Or possible that you did not activate your Office software after installing it.
To check if it is activated you can go to start , Word 2007 and click on Office Button ' Word Options ' Resources ' Activate. If you are already activated, a dialog box saying so will appear. If ynot activated, the Activation Wizard will start. If you have an expired free trial version, a dialog box will prompt you to enter a valid product key or convert (purchase a key) online.
Mar 17, 2011 | Computers & Internet
Tip
Keyboard shortcuts for Microsoft Windows XP, Vista, 7 and Microsoft Office
Windows
Windows Key+E
This shortcut allows you to open Windows Explorer with one quick keystroke.
Alt+Tab
This allows you to easily toggle back and forth between all the windows you have open. You can also use this to switch between windows in the same program, making multitasking real easy.
Windows key+Tab
This lets you scroll the items on the taskbar, and in Vista, it starts Flip 3D for a fun graphical spin on the same idea.
Alt+F4
This shortcut is a quick way to close a window in any program without using your mouse to hit the X in the upper-right corner.
Windows Key+M
This allows you to minimize all of your open windows, leaving just the desktop left exposed. To restore the windows, hit Windows key+Shift+M. Another quick way to do this is Windows key+D, which shows your desktop; to restore, just repeat the same keystroke.
Ctrl+Drag
There are many ways to copy a file, but this just might be the easiest. All you have to do is click on the file, hold, and drag it into its desired location. This works the same as another handy shortcut, Ctrl+C.
Windows Key+U+U
This is the shortcut for quickly shutting down Windows by hitting the Windows key (don't hold it down), hitting U to reach the shutdown menu, and then hitting U again to shut down.
Windows Key+Pause
This is a quick way to get to the Systems Properties menu.
Shift+Delete
If you want to delete a file-and you don't want to deal with it later in the Recycle Bin-this is the way to go. Just be absolutely sure that this is a file you won't want back!
To bypass the Autorun when inserting a CD
Hold Shift While Inserting the CD.
Microsoft Office
Ctrl+U, Ctrl+B, Ctrl+I
Used to snap to underline, bold, and italicize without the mouse if you press Ctrl+U (underlining), Ctrl+B (bolding), or Ctrl+I (italicizing).
Shift + Arrow Keys
Holding shift and pressing one of the arrow keys will highlight text in Word (or a group of Excel cells) without the mouse, selecting in the direction the arrow points.
Ctrl+Z, Ctrl+Y
Undo an action by hitting Ctrl+Z; if you change your mind, Ctrl+Y will redo the undo.
Microsoft Office - Excel
F1
Opens a help task pane
F1 + Ctrl
Opens or closes the help window
F2
To edit the text in the active cell
F2 + Shift
To write a comment in the active cell
F2 + Alt
Opens the save as dialog box
F3 + Shift
Opens the insert dialog box
F3 + Ctrl
Opens the define name dialog box
F3 + Shift + Ctrl
Opens the create name dialog box
F4
To redo the last command
F4 + Ctrl
To close the workbook window
F4 + Alt
To close the excel program
F5
Opens the Goto dialog box
F5 + Ctrl
brings back to the first level of workbook
F6
To shift between help taskbar and the excel window
F6 + Shift
To goto the previous square in the open worksheet
F6 + Ctrl
If more than one workbook is open to switch between them
F7
To open spelling correction window
F7 + Ctrl
When workbook window is not maximised it will move the window
F8
To activate / deactivate extended mode
F9
Will calculate all the worksheets in all open workbooks
F9 + Shift
Will calculate the active worksheet
F9 + Ctrl
To Minimise the workbook window
F10
Will select the menu bar
F10 + Ctrl
To open minimised window
F11
Will create a chart using the current range
F11 + Shift
To select a new worksheet
F11 + Alt
To switch between visual basic editor and the worksheet
F11 + Alt + Shift
Opens microsoft script editor
F12
Opens save as dialog box
F12 + Shift
Saves the active workbook
F12 + Ctrl
To open the Open dialog box
F12 + Ctrl + Shift
Opens the print dialog box
on Jan 01, 2011 | Computers & Internet
Tip
Hacking Your Way Through the Interface
Use Registry hacks to make a grab-bag of great interface changes.
Hidden in the mazes of the Registry are countless ways to hack XP's interface. Here are some of my favorites.
Hide All Icons in the Notification Area
The System Tray, also called the Notification Area, is the small area on the far-right side of the Taskbar, in which utilities and programs that run in the background, such as antivirus software, show their icons.
I don't find it a particularly intelligent use of screen real estate, so I'd prefer not to see the icons there. To hide them, run the Registry Editor [Hack #68] and go to HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer. Among other things, this key controls the display of objects throughout XP. Create a new DWORD called NoTrayItemsDisplay. Assign it a value of 1. (A value of 0 will keep the icons displayed.) Exit the Registry and reboot.
While you're at the HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer key, you can also delete the My Recent Documents icon on the Start menu. Create a new DWORD called NoRecentDocsMenu. Assign it a value of 1. (A value of 0 will keep the icon displayed.) Exit the Registry and reboot.
Hide Only Certain Icons in the Notification Area
You might like to display some icons in the notification area but hide others. If so, you can hide icons on a case-by-case basis. You'll do it by delving through menus, though, not by hacking the Registry. Right-click on the Taskbar and choose Properties → Taskbar. The Taskbar and Start Menu Properties dialog box appears. This dialog box, as the name implies, lets you control how the Taskbar and Start Menu look and function.
In the Notification area of the dialog box, check the box next to "Hide inactive icons," then click Customize. The Customize Notifications dialog box appears,
Click on the program's listing in the Behavior column, and choose from the drop-down menu to hide the icon when the program is inactive, always hide it, or never hide it. Click OK twice. Your changes will take immediate effect.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
The Update Assistant keeps opening a dialog box stating that it has no access to the router. But whenever I try to do anything in the dialog box--click a button or close the dialog--an Internet Explorer...
1.Press Windows logo key + R, type winver and hit Enter key.( Check the version details of Windows 10 installed on your computer).
2.Shutdown your device ,restart it back and then initiate the upgrade to see if goes correctly this time.
If any third party Antivirus or Online security software is installed, then try to disable it for a moment then try to initiate the upgrade to see if it goes correctly.
In case problem still persist, then try to upgrade it in Clean Boot state.
1. Press Windows Key, type msconfig in the search box, and hit Enter.
2. On the Services tab of the System Configuration dialog box, tap or click to select the Hide all Microsoft services check box, and then tap or click Disable all.
3. On the Startup tab of the System Configuration dialog box, tap or click Open Task Manager.
4. On the Startup tab in Task Manager, for each startup item, select the item and then click Disable.
5. Close Task Manager.
6. On the Startup tab of the System Configuration dialog box, tap or click OK, and then restart the computer.
Apr 08, 2017 | NetGear WNDR3300 - RangeMax Dual Band...
I want to activate my windows ultimate
To activate your copy of Windows Vista, fllow these steps:
1. Find your 25-digit yellow product key sticker in your box.
2.Go on Start menu, right click Computer, then click Properties.
3. Scroll down and your should see the Windows Activation section. Click on Activate Windows.
4. Respond to the UAC dialog box.
5.Type in your product key and click activate.
Feb 05, 2010 | Microsoft Windows Vista Ultimate Edition
Code 10 cd/dvd
Lets follow this:-
1. Choose Start > Run..
2. Type regedit in the Open text box and click OK.
3. Expand my computer - Expand HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4.On the right hand side, you'll find upper and lower filters, select them one by one and delete.
5.Restart PC and hope it works for you.
Note:Create a restore point before you delete any key from registry.
Thanks
Oct 07, 2009 | Computers & Internet
When I try to type something in microsoft word, it says the modification is not allowed because the selection is locked and I cant type anything.
If this only happens in one particular document, try opening that document and clicking on Tools | Unprotect Document.
If all new and existing documents are locked for editing, then it's probably because you have not activated your Word/Office software, or because you have an expired trial version of Office. What happens if you start Word and click on Help | Activate Product? If you are already activated, a dialog box saying so will appear. If you are not activated, the Activation Wizard will start. If you have an expired trial version, a dialog box will prompt you to enter a valid product key or purchase a key online.
Please let me know if this has been helpful or if there is anything else I can do. Thank you.
Sep 19, 2009 | Dell Inspiron 1000 Notebook
Some letters like ( a;e,i,o,p ,y) ar nt working on the keybo
for people who activate them accidentally. If you decide you need to disable a key, just follow these easy steps:
1. From the Tools menu, select Customize…
2. In the
Customize dialog box, click Keyboard
3. The Customize Keyboard dialog box will open
4. In the scroll box beneath the Categories label, select All Commands
5. In the Commands scroll box, find the command name for the key or keystroke (you’ll have to do some searching to find the specific key you wish to disable, but here’s a freebie: to disable the Insert key, select overtype)
6. Highlight the key or key sequence in the box below the Current keys label
7. In the drop down box beside the label Save changes in: select Normal to apply the change to all documents created in Word. To disable the key only to the current document, select the document name from the list
8. Click Remove and then Close
9. Click Close on the Customize dialog box
Dec 18, 2008 | Gateway 2520915 Keyboard
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Keyboard scramble
You have different keyboard layouts installed.
Standard: qwerty, asdfgh
Dvorak: ‘,.pyf, adeuid
To prevent the keyboard from unexpectedly switching up on you, open your control panel, select Regional and Language Options.
In the Regional and Language Options dialog box, click the languages tab, select the details button at the top of the dialog box.
In the Text services and languages dialog box, under installed services: select the Keyboard United States-Dvorak service and then click the remove button, click ok, click ok.
Dec 23, 2007 | EliteGroup P4VMM2 Motherboard
Microsoft Wireless Optical Desktop Pro Keyboard Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
