Question about Brother LS-2125 Mechanical Sewing Machine
My needle isn't picking up my bobbin thread. I have not sewed in a looooonnnnnngggg time so I need help. The machine works great because my mom used it before she gave it to me.
    Genius:
  • 1,788 Answers
Have you changed the needle? Do you have it inserted with the flat side facing away from you, towards the back? Double check your threading, and hang on to your top thread when the needle goes down into the bobbin area to pick up the tail of your bobbin thread. If, you do not have the manual go to www.brother-usa.com and download one for free. Click on home sewing machine support and find your model number. I suggest saving it to your computer besides printing it out, then you always have a copy. You never know how long the company will keep the manuals for free. Good luck and happy sewing
Posted on Oct 06, 2010
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
Machine just quit picking up bobbin thread and sewing in the material. It is just making holes in the material.
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Needles need to be replaced every 2-8 hours of sewing time, on average, or about 1 needle per garment. A needle that has hit the presser foot or needle plate is "dead", and needs to be replaced to (and eventually, you'll need to buff out the rough spots on the presser foot, and needle plate).
Common causes of skipped stitches (stitching that looks like
_ _______ _ _ _______ _ _____________ instead of _ _ _ _ _ _) or of not picking up the bobbin thread are: dull or damaged needle, needle in backwards, needle not fully up in the needle clamp, needle too small a size for the thickness of fabric, dirty machine, misthreaded machine, and way, way, way down on the list, machine out of time.
Jan 14, 2014 | Singer Sewing Machines
My sewing machine will not pick up the bobbin thread
If a sewing machine fails to pick up the bobbin thread, it's usually because the needle isn't fully in the needle bar... OR its the wrong size needle for the machine.
Jul 26, 2012 | White Sewing 2200 Multi-Tasker
It stopped picking up the bobbin thread while sewing. In the middle of a zig zag sewing project, it stopped picking up the bobbin thread. I cleaned the bobbin area and needle area and tried again and it...
You can take the slide plate off, that your needle goes through and watch to see if the arm grabs the bobbin thread, if you can get it to pick up, than slide scissors or something flat under your needle and manually pull both threads through, replace the plate.
Your bobbin thread could be wound to tight or spliced threads on it, and your tension needs to be adjusted. If your using a pedal, try setting to a slower speed.
I would try a different bobbin and thread it manually as in the step I mentioned, if you can't see the arm grabbing it, you will need to check to see if you have loose threading jammed in youir machine, if this isn't the case and adjusting the tension dosen't help...than you will need to replace the bobbin casing.
Kind regards!
Sep 12, 2011 | Janome 2049LX Mechanical Sewing Machine
My machine is new and worked briefly but now . . . . the machine is threaded correctly and the bobbin is placed correctly. When turning the knob for the initial pick up of the bobbin thread, it does not...
You have described your problem just fine. Have you just changed the needle in your machine? If so, check it is in the right way, you want the flat shank to the back.
The needle has a scarf (scoop out) at the back - if it is facing to the front then the rotary hook (bit that goes around the bobbin and catches the top thread) can't catch the needle thread behind the needle.
Also check needle is fully up into the housing, this could also cause problem.
I'd suggest that you visit www.sewingabout.com and check out the pages on general sewing machine use, care and threading up, lots of helpful pictures and information which may be of assistance to you.
If it isn't your needle backwards (very easy to get wrong, happens all the time), then the timing could be out, which isn't so easy, but as its new I'd be very suprised if this was the fault. Just check needle, make sure top and bottom threads are threaded correctly and have another go. Also, remember to turn flywheel towards you.
Jul 14, 2011 | Singer 7444 Mechanical Sewing Machine
I have an older Elna Lotus SP and I can't get the bobbin to spin. I'm pretty sure I have the bobbin in correctly (right side up, thread through the 'spring' in the back so it 'clicks' and up through hole...
Try inserting a new needle, and see if that helps. Make sure that you have the flat side facing the rear of the machine. If not, it may need a tune up. I understand where you want to keep it for sentimental reasons, so it may well be worth it. Just make sure that you pick someone who knows machines. I saw a free manual online for your machine, www.sewingonlineco.uk/instructions/elnalotus/. I did notice that, if it hasn't been oiled, it needs some in the hook area of the bobbin case. Hope, that I helped you. Good luck
Nov 05, 2010 | Sewing Machines
The top thread won't catch the bobbin thread to pull it through. It almost seems like it doesn't go around to pick it up. Or is the bobbin thread supposed to pop up more for pick up? This is my Mom's...
check the needle to see if it's damaged
have a thread tail for the top thread & bobbin thread of 3-4 inches
try this & see if it helps you
make sure there's a 3-4 inch bobbin thread then, hold the top thread tail (3-4 inches) with your fingers away from the needle & then use the handwheel on the right side of the machine & lower the needle down into the bobbin area & see if it pick up the bobbin thread that way
make sure there's no lint or loose threads in bobbin area
Sep 24, 2010 | Sewing Machines
The bobbin thread appears up through the hole by the foot, but the needle doesn't seem to be picking it up and advancing the thread properly, so when I sew, the bobbin thread isn't engaging. I have a JC...
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Best Wishes Martyn
Bargain Box in Australia
Sep 07, 2009 | Sewing Machines
Singer Inspiration 4205... doesn't work!
Check the position of the bottom piece that holds the bobbin carrier to the left so it rides smoothly on the rotating hook that carries the upper thread around the bobbin. I found my wife"s machine loose so the bobbin carrier was out of position and not riding on the ledge of the rotating part. loosen two screws and push it to the left and tighten.
If upper thread bunches below the material it needs more tension so it pulls back up through the material.
If the old singers were fords this is a yugo
(been fixing and adjusting her machines for years. ))
Dec 13, 2007 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
165 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
