Question about Whirlpool ES5FHAXS Side by Side Refrigerator
Everything in freezer is frosty and fridge is not as cold as it should be also little vent in fridge part on freezer side where cold air used to come from is all frosty
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Everything is freezing. Local repairman says the
Hi, what he is talking about is panel in the vent from the freezer to the fridge. Basically when you want the fridge colder a little panel (damper) inside the vent opens and allows more cold air in the fridge. When you want it warner the damper closes and allows less cold air into the fridge. This damper is controlled by the fridge control. What your repair guy is saying is the door is stuck in the open position which is allowing too much cold air into the fridge and freezing the food. if you have any other questions please feel free to comment. Mike
Dec 20, 2009 | GE PSS29NHNWW Side by Side Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Only the freezer side is working
I don't think the darkness is related to the fridge not being cool. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge side is not cooling, freezer side is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 08, 2009 | Refrigerators
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MBB1954GES not cold. Fresh food area warm, motor not on. Freezer OK.
Check the freezer fan is running with the door switch pushd in by hand, check the back wall of the freezer for frosting if it's frosty check the defrost system eg defrost element, Defrost termination stat and defrost timer. If the freezers running perfect check the fridge difuser/damper and see if it's open this is the part that opens and closes the vent between the freezer and fridge to allow cold air into the fridge. The Damper is up the top left corner of the fridge. cheers.
Mar 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Whirlpoolpool side by side
The pattern of frost buildup would indicate to me that the freezer door may not be fully closing due to a product on the door or shelve. Frost only on the back wall would indicate a defrost system problem. Frost like snow on product packages indicates air leaking into the freezer in some way.
Nov 11, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Sep 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Whirlpool ES5FHAXS Side by Side Refrigerator Logo
240 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
