Question about JUMP START SYSTEM
Jump and start unit is dead,how do I recharge this unit ? I have tried to recharge by plugging unit in at the ac plug and let it charge for several hours, what am I doing wrong ? How do I know when unit is fully charged and ready for use ?
    Sergeant:
  • 198 Answers
These units have a meter on them that shows if it is full or dead. If it will not charge from an AC wall socket, the unit is probably no good. Check the charger that it comes with to make sure that it doesn't need to be reset. If it has no reset button, you may need to return it for an exchange.
Posted on Oct 06, 2010
    Sergeant:
  • 406 Answers
To see if it not a bad battery try this..Turn your jumper on hook it, the jumper to the battery in your vehicle just as you would to jump it..start your vehicle and let it run for ten min or so..your alternator will charge it if it will take a charge...if this works your charging system on the jumper or charger is bad..to check your charger plug it in the wall then using a multi meter set it on 12 volt readings put your red + into the center of the plug and then touch the minus - to the side of the plug..you should see 12 volt being put out if the charger is ok..if it is not ok use the car charging system to keep the jumper battery topped off..when using it..good luck..
Posted on Sep 29, 2014
I have vector vec013 lost charger can i charge it with car battery charger
Posted on Mar 27, 2011
How do I recharge a Motor Trend jump starter
Get a recharge cord for the unit, plug it in and recharge.
Jun 28, 2014 | Power Center Jumpstart 11-411
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
My 1690 don't start black screen.
There could be a couple of reason why laptop didn't start-up. Basic: the battery is dead and need to be recharged. Possibly the battery isn't keeping charge and the AC power charge is un-plug from the wall. Leaving the laptop without power. Make sure everything is plugged in and try to power it up. It that doesn't work then it could be the power supply in the laptop it self. Good Luck!!!
Mar 15, 2011 | Acer Aspire 1690 Notebook
Need to recharge ac in 1995 chevrolet blazer. Not
1995 should have 134A. Look on the compressor and in the middle of it will be a sticker that says 134a or r12. If it is r12, you must retrofit it in order to charge it yourself.
Jun 24, 2009 | 1995 Chevrolet Blazer
My MPC t2300 laptop wom't turn on.
The Transport T2300 has an internal battery that will run the laptop for several minutes after the main battery goes dead. This feature allows you to save your work and shut down safely. If you run the laptop until both batteries are dead, even a brand new battery can't start the unit again. You have to follow this procedure:
1.Unplug power cord
2. Remove any attached periphal components including the cd rom and/or floppy disk module if you have one. Both remove with a push button switch located on the bottom of the unit.
3. Plug in power cord and charge the unit for a minimum of 24 hours straight. 30 hours is better. This whole time will be spent slowly recharging the internal back up battery.
4. Once that is done, unplug power cord again and reinstall any floppy/cd drives. Plug power cord back in now and charge for at least 24 hours again.
If your backup battery is dead, you can't charge the main battery or turn the unit on. The longer you charge, the better. We had one unit here that had to be on the initial battery backup for 72 hours before it finally took hold. Then, one overnight recharge on the regular battery and all was well.
If you need drivers or manuals for the 2300, all are available on cd at mpcsupport@cox.net for around $9.50 including shipping, handling, and owners manual
Apr 11, 2009 | MPC Computers TransPort T2300 Notebook
I have a car jump starter unit that was left and went dead flat. Now it will not take a charge pluging in the charger?
Unfortunately, a Jump Starting Unit which no longer takes a charge usually means the internal batteries had gone bad. On some charging units, the replacement batteries are available through the manufacturer, but more times than not, it's less expensive to replace the Jump Starting Unit.
Nov 09, 2008 | Energizer Rechargable Battery with Charger
Dead batteries when fully charged
Does it work with "no batteries" - only plugged into power source? check your usb cable by trying to power up something else.
Jun 28, 2008 | Fuji FinePix S7000 Digital Camera
Battery will not take charge from wall unit
Remove the battery for several minutes, replace the battery and plug the wall socket in, leave it for several hours. The battery is probably too dead to do anything, and recharges very slowly. If this doesn't work, try a replacement battery, before you send the unit in for repairs.
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
Treo 650 "Dead Screen"
Try plugging in your Treo as if you were charging it.
Then click the reset button in the back.
This should reset the charging mechanism inside.
See if the Treo starts to charge again after that by letting it sit for 1-2hrs.
Jan 04, 2008 | Palm Treo 650 Handheld
JUMP START SYSTEM Logo
1,959 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
