Question about Samsung Televison & Video
How do turn off BD wise? The menu is all highlighted exept the BD wise option and it will only go to 576p resolution
2 Suggested Answers
mastersaintx
  • 928 Answers
SOURCE: i own a teac hdb840
There are instances that the input cable from a settop box is unable to output a clear enough signal to the projector which is why the projector will switch over to a lower resolution that it can display. Check your cable as well as recheck your settings on the TV and settop box again. But do make sure that you check if your cable is good enough. An option would be to try it on another system if possible.
Posted on Aug 04, 2008
My player wont load rented blu rays. I have cleaned the lens, done all the unplugging and replugging, and i have loaded older blu ray disks successfully. going to try a hard reset now.
hi donald.
this is all i could find at the mo,so not sure if this will help you out.if not go to the link and the bottom of this page might help you as well.
Blu-ray disc won't play on Blu-ray player [ Edited ]
Options ‎03-01-2013 09:34 AM - edited ‎04-08-2013 05:42 AM
If you are having problems playing a blu-ray disc is your blu-ray player, try the following.
1) Check the firmware-make sure you have the latest version. If your BD player uses the Xross media bar, following these steps:
Press the Home button.
Select setup
Select System Settings
Press the Enter button on the remote.
Scroll down and select System Information and press enter.
The Firmware version will appear on the screen. Write this number down and go to esupport.sony.com to see if you have the latest version. Just follow the instruction to perform the update. Check out this video.....it will walk you thru the steps I just described.
http://www.youtube.com/watch?v=0lI2IaK3XkA
2) If your BD player doesn't have internet connection, you can check the firmware version by:
Press the System Menu button.
Highlight Setup and press the ENTER button.
Highlight Video Setup press the ENTER button
Highlight TV Type and press the ENTER button
On the remote, press the Blue button
The current firmware version of the player will display. Write this number down and go to esupport.sony.com to see if you have the latest version. Just follow the instruction to perform the update. Check out this video.....it will walk you thru the steps I just described.
http://www.youtube.com/watch?v=kOq-zba_-5c
3) Some BD players requre that a USB memory device is inserted in the EXT slot of the player prior to playing the movie. It's recommended to use at least 1GB. If you already are using one and run into a disc not playing, try removing the USB device and plugging it back in.
Here's a few more things you can try.
1. Reset the BD Player:
  • Remove the disc from the BD player.
  • Turn off the BD player.
  • Unplug the power cord of the BD player from the electrical outlet.
  • Let the player remain without power for one minute.
  • Plug the power cord back into the electrical outlet.
  • Turn on the BD player.
  • Insert the disc into the BD player
2. Make sure that the Parental Control settings are not set to "On".
3. If the BD player supports the BD-Live feature, set the BD Internet Connection setting to "Do Not Allow" and delete any conflicting BD-Live date from the BD/DVD Viewing Settings menu.
won load rented blu rays Google Search
Nov 03, 2017 | Televison & Video
Ps3 and HD TV stuck on 576p
Turn off the PS3.
PRESS THE POWER BUTTON AND HOLD IT DOWN UNTIL YOU HEAR 2 BEEPS.
THIS WILL RESET YOU PS3 VIDEO
Jun 27, 2013 | Video Game Consoles & Games
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
For some reason mt blue ray player was saying 1080i and not p so i went into menu and changed to 1080p but tv is now saying mode not supported and i cant get back into the menu on the blue ray player to...
Try to make use of the yellow video cable, the cable that is part of the RCA cable and try to set the TV to AV1 as soon as the video cable is connected from your BD player to your TV. Turn on your Bd player and you can now set the TV to its correct resolution. Best thing also to reset oyur bd player back to its factory settings.
Oct 22, 2010 | Samsung BD-P1400 Blu-Ray Player
How to disable the resolution notice on VG930m
Use your monitor buttons to look for Resolution Notice and turn it off.
To disable the notice on ViewSonic 23" LCD Monitor , use the buttons on the
front of the montior to do the following:
* Press #1 button
* Use down arrow to highlight Setup Menu and press #2 button
* Use down arrow to highlight Resolution notice and press #2 button
* Select Disable and exit!!
To disable the notice on NEC LCD 1765 monitor
* Press button #5 on the monitor
* Scroll up and down the menu list with Montior Button #4 and then select
with Monitor Button #5. Go to "Advanced menu" set the Resolution notice to
OFF.
Nov 02, 2009 | ViewSonic Computers & Internet
Date stamp option in menu will not highlight to change it just skips past it change daye and time
For some cameras this option only works when the camera is set to a specific resolution. Some calle this resolution "Postcard" resolution, and is usually 1200 pixels width. Try setting your camera to its other resolutions to see if this ocrrects the problem. Suggest that you start with 1200 x 900 resolution. Keep in mind that this 1200 x 900 gives only 1 megapixel resolution. Most newer cameras are capable of taking much higher resolution pictures, so this may be a trade-off if you want to use the date stamp option.
May 10, 2009 | Cameras
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Jun 22, 2008 | Audio Players & Recorders
Televison & Video Logo
539 people viewed this question
Jerry Greenberg
Jerry Greenberg
