Hello, I have Samsung 46 tv less than 2yrs old, when you turn it on there is shadowing and three horizontal lines on the tv. However, after about 15-20 mins the shadowing and lines disappear. I thought it was the cord, but it does it when playing a dvd and when i put it on cable. I checked all the leads to see if any were loose, I looked at the capacitors to see if any tops were bulging, and cleaned the t-con ribbon -nothing worked. Please advise if there is something I am missing or does it sound like a control board issue.
  • 10,594 Answers
I'm afraid, it is lcd panel (screen) issue that can not be repaired and only solution is to replace lcd panel (screen) that would cost you approx 80% of new tv cost.
Thanks.
Posted on Oct 06, 2010
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
Samsung 46" D6900 led tv horizontal lines
This can be an issue with the Timing Control circuit board, but that is just an educated guess.
Jul 19, 2017 | Samsung Televison & Video
Why does my samsung ln40d630 lcd tv have a horizontal line across the screen about mid height? The line is present using all the different sources.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 13, 2014 | Samsung Ln40d630 40-inch 1080p 120 Hz Lcd...
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
Our three year ol Samsung TV has dark horizontal lines across the top of bottom of the screen. It is getting worse
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Apr 30, 2011 | Samsung HL-R6168W 61" HDTV
50. In LCD samsung has pink vertical lines
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Mar 03, 2010 | Samsung LN-T4665F 46 in. LCD Television
Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Jun 04, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
May 25, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
