Question about GPX Televison & Video
Remote quit working. I changed batteries: that didn't help.
  • GPX Master
  • 6,993 Answers
Check the battery terminal of the remote control. Check if the battery terminal is rust or not. If the battery terminal is rust, it won't make the battery contact, use a flat screw driver to scratch the battery terminal.
Also, you can further open the remote control, check if the battery terminal is well connected to the remote board.
If the above does not solve the problem, then you might end up getting another remote as this one might be defective.
Good luck.
Posted on Oct 06, 2010
My lg tv suddenly stopped working with the remote? Didn't change anything. Just woke up and the remote would not work. Changed batteries but no luck. Tv works but remote no longer works with it
Visit this site. Type in the site name "Electro-help" in yahoo search box. Pull up older posts there. You will get all details. Codes, setup proceedings etc:-
Jun 09, 2012 | LG 32LG30 32 in. LCD HDTV
Nissan 2004 key fob not working
Have you tried replacing the rubber pad buttons? We had the same problem. The remote quit working and we changed the battery and it still didn't work. I was actually online looking for a replacement and came across something about the the rubber pad buttons. We ordered a replacement for $9.95, it came two days later and was a cinch to change out. The remote has been fine, ever since.
May 30, 2012 | 2004 Nissan Sentra 1.8
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
My remote control for my TV won't work. I changed
See my response to your other identical question.
Mar 14, 2012 | Philips Televison & Video
My remote for sony dvd player NS 590 p suddenly stopped working. I repleced the batteries but it didn't help
if its not batteries it will be a replacement remote. try cleaning the terminals and see if helps,
Dec 10, 2011 | Televison & Video
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
Oct 20, 2011 | Insignia IS-LCDTV32 32 in. Television
MY TV REMOTE IS NOT WORKING ?
Check the battery of your remote.Try to replace new battery.If didn't work.Try to open and clean the contact of the bottun of the battery.If didn't work, its need to replace the crystal of the battery.Try this sugestion.Thanks
Aug 26, 2011 | Sony KDL32EX700 32 in TV
The remote for the fan quit working. New batteries didn't solve the problem. The are no strings to pull on/off, just a light switch which does turn on the light.
Just in case, I'll ask, Did you also change the remote receiver batteries, located behind the fan's cowling? If not, that should do the trick. Don't feel bad if you didn',most folks do remember they're there.
Jun 09, 2011 | Hunter Heating & Cooling
The remote for my 20: LCD TV has stopped working, i have changed out the batteries and even bought a new one but still nothing. What should i do?
there are several things to try.. first, isolate the source of the problem... get a universal remote (borrow one from a friend if you don't have one--get the instructions, too)...then program it for your tv...if the UR doesn't work, then there is a problem with either the tv or its remote sensor...try the troubleshooting guide for the tv or call the customer service line (ask if there are similar probs going around for that model..you might get some special incentive to quit ****, if so..) If it DOES work, then it's your remote...best thing to do is make sure that the batts are good (which you did....but make sure you didn't get a fresh set of batteries from the same bad lot - it happens)...then check to make sure that the connections for the batteries are not missing, broken, or bent.. Look for corrosion, loose wires, solder gone...anything you can see which might cause your problem...Nothing visible? send it back..or try to exchange it at the store you bought it from, if it's a currently selling model Hope that helps you
Feb 22, 2010 | Televison & Video
Not all the buttons are working on the remote
You may have to change your code. http://www.urc.philips.com/ This link will take you to the Philips Support site where you can download manuals and code sheets for your remote.
Mar 15, 2009 | Philips PM435S Remote Control
Televison & Video Logo
98 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
