Question about Brother MFC-8480DN All-In-One Laser Printer
SOURCE: have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Posted on Apr 26, 2009
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !!
On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy
scan window OR the laser scan window can get dirty. If the fax scan
window is dirty, you see streaks on outgoing faxes and copies (but NOT
incoming faxes). If the laser scan window is dirty, you see streaks on
all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
SOURCE: I have a brother MFC-7430 all-in-one - Fax won't work
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Hope this helps. Please rate my response.
Thanks.
Posted on Mar 16, 2010
SOURCE: I have a Brother printer MFC-8480DN and on the lcd
There is an installation sheet in the box the drum unit came in that tells you how to reset the drum indicator. Here is a link to my tip posted here at Fixya that may help you as well. If it works for you then please return to this posting as give feedback.
Thank You for using Fixya.
http://www.fixya.com/support/r5014960-brother_mfc_laser_printer_facsimile
Posted on Jul 23, 2010
Nov 15, 2013 | Brother MFC-8480DN MFC8480DN...
Nov 04, 2013 | Brother MFC-8480DN All-In-One Laser...
Apr 28, 2012 | Brother MFC-8480DN All-In-One Laser...
Feb 27, 2012 | Brother MFC-8480DN All-In-One Laser...
Jul 28, 2011 | Brother MFC-8480DN All-In-One Laser...
May 13, 2011 | Brother MFC-8480DN All-In-One Laser...
May 04, 2011 | Brother MFC-8480DN All-In-One Laser...
Feb 02, 2010 | Brother MFC-8480DN All-In-One Laser...
601 people viewed this question
